vortech s4/gt supercharger kit (mostly complete) for sale
made some changes on my '89 s4 so the kit that was on it is for sale. probably have around 5000 miles on it. made 445rwhp, 439rwtq in 11/06 on a dynojet with std correciton.
i have a number of pics but here is what is included (and needed)
-vortech v1-s trim supercharger with 2.87 6 rib pulley and idler pulley (9 lbs boost)
-vortech air to water intercooler with intake boot/spacer to fit mass air
-vortech super fmu with associated fuel lines and adapters as well as extra rings and spring
-delta-p bracket with mounting hardware and tensioner adapter
-delta-p power steering and smog pump pulleys
-delta-p crank pulley. NOTE this pulley has been damaged and i would not recommend using it (although i did.) the last time i talked to delta-p they could supply a new one for $650
-intake plumbing/k&n from drivers front wheel well to supercharger
-8 30lb ford injectors (these were cleaned and flow matched prior to my using them)
-2 12" permacool fans (#19122)
-oil line to supercharger with adapter
-aluminum deflector for top of radiator
-various bits of hardware and all hose clamps for above.
-basic instruction manual
what is needed:
-plumbing from supercharger to intercooler (i can probably come up with some of that)
-blow off valve
-supercharger belt (i can tell you what size)
-oil return from supercharger to sump
-oil filter sandwich adapter (to supply supercharger)
-intercooler plumbing/pump/heat exchanger
-breather setup (i use 928 specialists)
-gauges
-front fan (if desired)
asking $3000 shipped in continental usa.
pm or email
what is needed:
-blow off valve
-gauges
pm or email
Such a smoken deal I'm tempted to try to buy it and try to figure out how to fit it on my 16v CIS motor. Even after I have decided not to boost.
Captain Obvious
Super User
Super User
This is a very good deal. Anyone that is thinking of boosting their 928 shoudl really thing aobut this. The non intercooled setup would work on early 32Vs and probalby even the 16V cars. Then sell the intercooler to recupe some of the cost.
