Porsche cleans out warehouse
The Parts Whisperer
We recently were awarded the bid on all 928 inventory that was slow moving and here is a sample of what we got. It will take a few days before it is all in our system and available for sale.
928110906 X 13 ONTARIO FUEL DISTRIBUTOR 1638.48
928110906 X 4 ATLANTA FUEL DISTRIBUTOR 1638.48
928604103AX 19 ONTARIO STARTER, REBUILT 245.6
92861813401 4 ATLANTA SEAT CONTROL UNIT 1016.64
92834105717 2 ATLANTA STEERING KNUCKLE 2005.28
92864116303 1 ATLANTA COMB. INSTRUMENT 3642.32
928552023064JX 2 ATLANTA DASHBOARD 1606.07
92854501804 2 ATLANTA REAR WINDOW 1539.36
92811321904 1 ONTARIO CATALYTIC CONVERTER 2856.26
92850191501GRV 2 ATLANTA BRACKET 1343.73
92850303103GRV 10 ATLANTA FENDER BRACKET 258.94
92864112403 1 ATLANTA COMB. INSTRUMENT 2067.3
92864196513 3 ATLANTA TACHOMETER 577.61
92851290103 3 ATLANTA HATCH LOCK W/ALARM 494.75
92850306219GRV 1 ATLANTA REAR QUARTER PANEL 1464.05
92850306113GRV 1 ATLANTA REAR QUARTER PANEL 1464.05
928618123DX 1 ONTARIO FUEL CONTROL UNIT 1383.85
92861010505 1 ATLANTA CENTRAL ELEC.BOARD 1373.17
92810521100 1 ATLANTA CAMSHAFT 1300.97
92861010519 1 ONTARIO CENTRAL ELEC.BOARD 1297.88
92860701509 1 ONTARIO ENGINE WIRING 1229.55
92857306305 2 ATLANTA FUEL COOLER 602.41
92853790202 1 ONTARIO SET OF LOCKS 1118.62
92810527200 1 ATLANTA CAMSHAFT 1099.12
928602032DX 1 ATLANTA DISTRIBUTOR 1096.1
92864199133 1 ATLANTA INSTR.CIRCUIT BOARD 1057.18
92861812415 1 ONTARIO IGN CONTROL UNIT 1017.48
92810541703 9 ONTARIO EXHAUST VALVE 109.48
92811301700 1 ONTARIO SMOG PUMP 925.63
92860221301 12 ATLANTA DISTRIBUTOR ROTOR 71.57
92861010500 1 ATLANTA FUSE/RELAY PLATE 851.87
92857301106 1 ATLANTA A/C CONDENSER 836.79
92850103105GRV 3 ATLANTA CROSS MEMBER 276.68
92863141600 3 ATLANTA FOG LAMP 268.45
92811600412 1 ONTARIO PRESSURE PLATE 769.27
92863193202 3 ATLANTA TAIL LIGHT 254.79
92810608002 1 ATLANTA BELT TENSION ROLLER 759
92812690101 1 ONTARIO MAGNETIC CLUTCH 739.85
92863192600 8 ONTARIO FOGLIGHT LENS 92.37
92811022500 9 ONTARIO FUEL INJECTOR VALVE 74.93
92811007906 1 ATLANTA FUEL INJECTION TUBE 639.97
92864197100 2 ONTARIO TACHOMETER 309.89
92810220803 1 ONTARIO FLYWHEEL 614.69
92809957315 1 ATLANTA A/C LINE 604.78
92851290102 2 ONTARIO HATCH LOCK W/O ALARM 290.75
92850447500 1 ATLANTA FENDER SKIRT 564.74
92864194902 2 ATLANTA TEMP/FUEL GAUGE 265.68
92863140600 1 ATLANTA ADDITIONAL HEADLAMP 521.3
92864196701 1 ATLANTA SPEEDOMETER 491.67
92860700202 1 ONTARIO ENGINE WIRING 438.32
92864196707 1 ATLANTA SPEEDOMETER 422.65
928551032085FV 1 ATLANTA LINING 421.89
92853790502 1 ATLANTA DOOR LOCK W/ALARM 417.92
92853790602 1 ATLANTA DOOR LOCK W/ALARM 403.9
92853790602 1 ONTARIO DOOR LOCK W/ALARM 403.9
92811021100 2 ATLANTA AIR CLEANER HOUSING 196.37
92853803202 7 ATLANTA MASTER W/ALARM (CUT) 54.42
92810605300 21 ONTARIO WATERPUMP IMPELLER 18.11
92850527902 20 ATLANTA REAR BUMPER SUPPORT 18.92
928106015 X 1 ONTARIO WATER PUMP 374.43
92810109302 1 ATLANTA SECURING PLATE 364.84
92864196506 1 ATLANTA TACHOMETER 356.15
92856401641 2 ATLANTA SUNROOF GUIDE RAIL 177.52
92835142701 1 ATLANTA CALIPER 348.32
92854310502 1 ATLANTA SIDE GLASS 347.56
92850409100 1 ATLANTA HEAT SHIELD 340.26
92861222201 2 ONTARIO A/C UNIT HARNESS 168.37
92810515304 1 ONTARIO CAMSHAFT COVER 335.11
92863141001 4 ONTARIO TURN SIGNAL LIGHT 82.1
92811315100 1 ATLANTA E.G.R. VALVE 327.02
92857467002 2 ATLANTA VAC LINE 163.4
92857309110 2 ONTARIO A/C LINE 161.1
92854310609 1 ATLANTA QUARTER GLASS 311.35
92854310509 1 ONTARIO QUARTER GLASS 311.35
92811315101 1 ATLANTA E.G.R. VALVE 309.79
92860510300 2 ATLANTA SOLENOID VALVE 148.37
92850448405 2 ATLANTA DOOR SILL RAIL 148.06
92875004105 1 ONTARIO HEADLIGHT SHAFT 295.94
92854341702 3 ATLANTA REAR WINDOW ORN.STRIP 97.57
92853763305 1 ATLANTA DOOR LOCK W/O ALARM 271.95
92862821306 1 ATLANTA WIPER ARM 271.61
92834791701 1 ATLANTA IGN.LOCK (CODED) 269.3
92863141600 1 ONTARIO FOG LAMP 268.45
92842402819 3 ATLANTA SHIFT ROD 85.51
92863193202 1 ONTARIO TAIL LIGHT 254.79
92850333403GRV 2 ATLANTA FENDER BRACKET 124.53
92850333303GRV 2 ATLANTA FENDER BRACKET 124.53
92811601323 1 ONTARIO CLUTCH DISC 248.55
9288030910270B 3 ATLANTA SEAT BELT RECEPTOR 82.8
92863193800 8 ATLANTA PLSTC LENS 30.73
92811022901 1 ONTARIO AIR CLEANER HOUSING 229.88
92853763902 6 ATLANTA SECONDARY KEY (CUT) 37.5
92855107306 2 ATLANTA LINING BRACKET 111
92810432851 23 ONTARIO VALVE GUIDE 9.65
92810461214 8 ONTARIO VALVE SEAT 27.35
92810390623 2 ATLANTA PISTON RINGS 107.13
92860291501 1 ONTARIO VACUUM TIMING UNIT 206.4
92852176404 2 ATLANTA SEAT ADJ COVERING 102.5
9288030220070B 1 ATLANTA SEAT BELT 198.76
92834703101 2 ONTARIO TIE ROD 98.27
92810461214 7 ATLANTA VALVE SEAT 27.35
92812601700 1 ATLANTA A/C COMPRESSOR SUPPORT 189.67
92811028203 1 ATLANTA AIR INTAKE PIPE 185.45
92850331702 4 ATLANTA FENDER SUPPORT 46
92864541102 2 ATLANTA SPEAKER 90.4
92880301503 1 ATLANTA SEAT BELT 177.84
92811127103 3 ONTARIO TAIL PIPE TIP 58.51
92852138626 1 ATLANTA FOAM SEAT CUSHION 173.34
92850110302GRV 1 ATLANTA MEMBER 167.4
92842390100 2 ONTARIO ACCELERATOR CABLE 82.83
92855106603 2 ATLANTA FOOT REST BOARD 82.43
92857467002 1 ONTARIO VAC LINE 163.4
92863710402 1 ATLANTA ALARM CONTROL UNIT 162.2
92864541300 3 ATLANTA SPEAKER 52.57
92857309803 1 ONTARIO A/C HOSE 155.26
92860612900 1 ONTARIO OXYGEN SENSOR 151.67
92810514605 1 ATLANTA TOOTHED BELT COVER 151.32
92850448405 1 ONTARIO DOOR SILL RAIL 148.06
92842402818 1 ATLANTA SHIFT ROD 147.25
92810313300 15 ATLANTA PISTON PIN BUSHING 9.66
92810390611 2 ONTARIO PISTON RINGS-97.0 71.73
92864160910 1 ATLANTA DASH BUTTON SWITCH 142.19
92856434102 1 ATLANTA SUNROOF FRAME COVER 141.97
92860611902 1 ATLANTA FUEL INJECTOR VALVE 139.27
92811106100 7 ATLANTA EXHAUST BRACKET 19.7
92861520101 1 ATLANTA A/C SOLENOID VALVE 136.65
92873103211CA9 1 ATLANTA SUN VISOR 134.94
92864191700 1 ATLANTA VOLTAGE/OIL PRESSURE 134.83
92811023102 1 ATLANTA FUEL PRESS.DIAPHRAGM 134.29
92810111551 3 ONTARIO ONE-HALF MAIN BEARING SHELL 39.82
92861311300 3 ONTARIO REAR WIPER SWITCH 38.79
92810513604 1 ONTARIO CAMSHAFT MOUNT 113.82
92835603101 1 ATLANTA FUEL LINE 109.2
92861632100 2 ATLANTA POTENTIOMETER 54.4
92820110702 1 ATLANTA FUEL TANK BASE 105.83
9286130310070B 2 ATLANTA POTENTIOMETER 52.57
92842331110 1 ATLANTA CLUTCH PEDAL 104.65
92852816102 9 ONTARIO PLASTIC HOSE 11.41
92852176304 1 ATLANTA SEAT ADJ COVERING 102.5
92855106205 1 ATLANTA FOOT REST BOARD 102.1
92880318303 1 ONTARIO SEAT BELT RECEPTOR 101.38
92860290200 1 ONTARIO DISTRIBUTOR CAP 100.75
9285434170770K 1 ONTARIO REAR WINDOW ORN.STRIP 97.55
92861206604 1 ATLANTA SPEAKER WIRING 94.97
92853726402 1 ATLANTA WINDOW LIFT GUIDE 94.27
92880308102 1 ATLANTA SEAT BELT RECEPTOR 93.28
92834352500 4 ATLANTA SHOCK ABS. MOUNT 22.83
92835194700 9 ATLANTA CALIPER GUIDEPIN 10.04
928347857021DB 1 ATLANTA HORN PAD 88.63
928347857027LD 1 ONTARIO HORN PAD 88.63
92850552202 9 ATLANTA BUMPER BRACKET 9.64
92860906105 2 ONTARIO IGNITION CABLE #5/#6 42.25
92880318302 1 ONTARIO SEAT BELT RECEPTOR 84.34
92850303104GRV 1 ATLANTA FENDER BRACKET 81.71
92850158203GRV 1 ONTARIO BEARING BRACKET 79.97
92864590101 1 ATLANTA NOISE SUPPRESSOR 79.68
92861222101 1 ATLANTA A/C HARNESS 76.02
92856410503 1 ATLANTA SUNROOF FRAME COVER 73.93
92857304550 1 ATLANTA DASH VENT FRAME 73.52
92860221301 1 ONTARIO DISTRIBUTOR ROTOR 71.57
92811075901 1 ONTARIO AIR PIPE 70.74
92834744108 1 ATLANTA STEER.PUMP PULLEY 68.72
92850544700 2 ONTARIO BUMPER ATTACH STRIP 34.29
92810773711 1 ATLANTA OIL DIPSTICK 67.11
92855938402 1 ATLANTA MUD FLAP 66.51
92861893100 1 ONTARIO RELAY 64.28
9286131880201C 1 ATLANTA SEAT HEATER SWITCH 64.17
928552309515XL 1 ATLANTA AIR VENT FRAME 63.74
928552309515XW 1 ATLANTA FRAME 63.74
928552309516ZH 1 ATLANTA FRAME 63.74
9286134310170B 11 ATLANTA ROSE 5.74
92810433655 1 ATLANTA VALVE SEAT 62.31
92833272230 1 ATLANTA TRANS DISC 60.02
92842425313 1 ATLANTA BRAKE LEVER 59.42
92861310701 1 ONTARIO DEFROSTER SWITCH 58.34
92851230702 14 ATLANTA NUT 4.03
92861310900 1 ATLANTA FOG LIGHT SWITCH 54.9
92855629203 1 ATLANTA SOUND ABSORBER 53.94
92830215210 1 ATLANTA BALL BEARING 98MM 53.66
92873114106 1 ONTARIO MIRROR MOUNT 50.14
92811090200 3 ONTARIO LOCK RING 16.69
92853705502 2 ATLANTA DOOR LATCH CABLE 24.6
92857408202 2 ATLANTA FLAP LEVER 24.44
92833351701 4 ONTARIO SHOCK RETAINER RING 12.06
92855548003 1 ONTARIO DOOR INNER SEALING 47.02
92860906108 1 ONTARIO IGNITION CABLE #8 44.83
92852181702 6 ONTARIO SEAT BUTTON 7.37
928521148026ZF 1 ATLANTA SEAT HINGE COVER 43.46
92857313702 1 ONTARIO FLAP VALVE 42.42
92863146800 15 ATLANTA TAIL LIGHT NUT 2.81
92830150203 2 ATLANTA TRANS.GUIDE BUSHING 20.79
92853711202 11 ONTARIO LOCK OPERATING ROD 3.65
92853771402 1 ONTARIO CONTACT SWITCH W/CABLE 39.73
92853771302 1 ONTARIO CONTACT SWITCH W/CABLE 39.73
9286133420070B 1 ATLANTA SWITCH 38.66
92830323322 3 ATLANTA TRANS.BUSHING 12.64
92842318700 1 ATLANTA CLUTCH CYLINDER ROD 37.23
Under the Lift
Mark:
Are those the prices you will be using at the end of each item? I checked 92834703101 and the number ($98) above is higher than your usual price ($70).
The Parts Whisperer
Originally Posted by Bill Ball
Mark:
Are those the prices you will be using at the end of each item? I checked 92834703101 and the number ($98) above are higher than your usual price ($70).
This will be interesting to see:
OUch! That the thin AC line with the flexible part at the end.
I am trying to create an AC system from a few different years, and I wonder if since this is only for 80- but the next cut off is -83, whether or not it would work with a later condensor, compressor, and evaporator.
The Parts Whisperer
The Parts Whisperer
Originally Posted by Sterling
that is for the highly skilled 928 do it yourselfer who has lost their impeller.
Administrator - "Tyson"
OB L-Jet Fuel Lines
928 356 079 00
928 356 081 00
One of the following:
928 356 031 01
928 356 031 02
928 356 031 04
928 356 079 00
928 356 081 00
928 356 031 01
928 356 031 02
928 356 031 04
