Do belt tensioners "burp" after filling?
928 Collector
Originally Posted by PorKen
This one. It's drilled into a oil return passage from the head.
![](https://members.rennlist.com/porken/TensionerBlock.jpg)
I used black silicone.
Thanks Bill. I want to at least get you out to look things over before I button it up. I have a killer August going, including a week in Minnesota so I'm not sure how I will schedule this.
928 Engine Re-Re-Rebuild Specialist
Originally Posted by heinrich
Btw Ken is that OIL or WATER? I thought it was WATER?
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
It just looks like the bleeder is leaking because oil from this hole drips right on top of the bleeder valve.
Former Sponsor
I love dreams....they always turn out so good.
Reality is that you need to remove the tensioner, fix the threads in the block and try again on sealing up the tensioner. Don't forget the circlip on the inside of the boot, that Porsche doesn't show in the parts diagram.
I agree, but it'll have to wait until next week.
The tensioner is not leaking, and I'm not 100% sure the leak is from that bolt (although it is stripped). I'm still leaking oil slowly and I need to confirm where it's coming from.
Thanks, Heinrich
I'll close this thread and continue in the new one:
https://rennlist.com/forums/928-forum/371246-stripped-belt-tensioner-mounting-hole.html
