928 Forum 1978-1995
Sponsored by: 928 Specialists
Tri-tip RMB
Old Jun 20, 2007 | 11:45 PM
PorKen's Avatar
PorKen
Inventor
Talking Tri-tip RMB
A bit short of a Gemballa, but it fits in the stock cutout.
With 3 x 1.5" ID, it flows more than a single 3", but quiets the X-pipe down, nicely. It even has a O2 port for dyno testing.
I tried two of these resonator tips on straight pipe (previous muffler shop RMB), but I could tell there was some restriction, because it made that cool 'ripping silk' sound at full throttle. Still, it made 298 RWHP. With the extra tip and 'expansion chamber', and a bit more cam retard, I hope to get over 300 at Louie's this weekend.
Old Jun 20, 2007 | 11:51 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Cool!! weird looking but still cool!
Are the tips from a resonator that are sold at almost every parts store?
Old Jun 21, 2007 | 12:13 AM
PorKen's Avatar
PorKen
Inventor
It took a few days for me to get used to it, but I like it now.
Yep, they are parts store weld-on chrome resonator tips, 2.5" OD, to attach to a 2" pipe, IIRC. I cut off the neck down, and welded them to the 'expansion chamber', which is made of bits of 3" pipes, cut lengthwise. The first version resonated, so I put in the 3/4" pipe through the center, like the factory resonators have. I also put a 1/4" pipe across the entrance of the tips, about 1.5" away, with the thought that the turbulence created by the pipe would put more sound into the packing of the tips.
Old Jun 21, 2007 | 12:28 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Don't take this the wrong way but when I first saw it, it reminded me of the 3 breasts hooker in Total Recall!
Old Jun 21, 2007 | 01:04 AM
heinrich's Avatar
heinrich
928 Collector
that is the fugliest thing I've seen since the hex headlights Sorry man ...
Old Jun 21, 2007 | 01:08 AM
atb's Avatar
atb
Porken,
Can you post a shot from further back showing the whole backside of the car, it would be good to get a little perspective on how the exhaust tips go with the shape of the car.
Old Jun 21, 2007 | 01:17 AM
ew928's Avatar
ew928
Owns the Streets
Needs Camber
It's like those crazy 3 barelled blunderbluss flintlocks from way back when.
1 shot. 3 kills.
Let see the whole rear with the triple RMB.
Old Jun 21, 2007 | 01:46 AM
PorKen's Avatar
PorKen
Inventor
The light was fading, so the pic is not so good. It pretty much looks like a regular double from the rear. It is a little bit tilted, I'm just too lazy to loosen the clamps and level it.
This is kind of a cool shot (to me ), of the initial revision.
Old Jun 21, 2007 | 01:55 AM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Originally Posted by PorKen
With 3 x 1.5" ID, it flows more than a single 3"...
Ken, verify my math for me. A 1.5" diameter tube has 1.77 sq in cross-section, x 3 pipes is 5.3 sq in. A single 3" pipe has an area of a little over 7 sq in. There are some variables with surface area of the tube relative to cross section that make the smaller pipes even worse than above numbers might suggest, compared with a single 3". It also looks like there are baffles in your pipes. Are they considerd in the 1.5" pipe size?
Old Jun 21, 2007 | 02:07 AM
PorKen's Avatar
PorKen
Inventor
Bob,
I don't know about your math, but my math was wrong. It's a little bigger than a single 2.5" pipe. I guess I'll need a couple more...a five-tip would be almost 9²"
1.5" is the innermost open ID. The OD of each unit is 2.5".
Three pipes will have less flow, but it's easier to control the sound level, versus a single large pipe.
Old Jun 21, 2007 | 02:39 AM
BrianG's Avatar
BrianG
Remember Zoomies??
Old Jun 21, 2007 | 02:53 AM
atb's Avatar
atb
PMB?
Porken Muffler Bypass?
Old Jun 21, 2007 | 03:52 AM
Darien's Avatar
Darien
Ken, can you post a sound bite??
Old Jun 21, 2007 | 04:02 AM
SharkSkin's Avatar
SharkSkin
Ken, why not go all the way? You know you want to...
Old Jun 21, 2007 | 04:28 AM
928ntslow's Avatar
928ntslow
Hey, Ken brought the car over to my house the other day and the first thing I noticed as he pulled into the driveway was the sound. I think I even said it sounded finely tuned. Had that well balanced European exhaust note. He showed me the tri-tip and this was the first thing that came to my mind ...
It needs one more pipe.
I remember his rear diffusers a couple of years back. I thought they were ridiculous, but ya know what? Ken comes up with more great ideas than not. So he can keep on comin' up with stuff no matter how foolish they may seem, cause you know he's got another one right around the corner thats gonna be a good one.
