TB/WP - difficulty removing the lower idler arm
Bill - you bring up a very good point. If it's not leaking - don't touch them.
My crankshaft and oil pump seals are currently leak-free. Although I have replacements on hand, I have decided to wait until the next TB/WP service to replace them, if necessary.
With proper cleaning and anti-seize on the install, at least the lower idler arm will come off without much difficulty for future service (I hope).
Thank you for your advice - I truly appreciate it!
Under the Lift
Originally Posted by mark kibort
I dont think we even put one back on with scots rebuild. Do all 928s have the idler arm at the bottom?
MK
MK
Under the Lift
Craic Head
Adam,
Glad you got it out. I didn't replace that roller or the crank gear, although I did replace all of the others. I think holding off on the crank seal is a good idea. Plenty of other variables will be replaced without messing with something that's (apparently) fine for now. Next time you do the belt you'll have the same opportunity, right?
So are you on to reassembly yet?
Mike,
The reassembly process has been delayed slightly. The c-clips and washers that hold the lower idler arm assembly onto the pins need to be replaced. The new assembly I have didn't come with clips and washers (should have checked first) so I ordered replacements this morning.
Adam
Adam
The rollers were on his first engine, and we put them on the last engine with the headgasket issue. however, i couldnt get it off, as those pins were a little bent and i had to use a mallet to install them, knowiing they were never coming off again! Now, when the belt was installed, those rollers (two little rollers) were not even touching the belt, AND if they ever did, well, the belt wouldnt be touching the teeth of the crank pulley! So, i didnt see a need for them, so his new engine doesnt have the rollers at the bottom.
mk
mk
Originally Posted by Bill Ball
In the earliest years there was just a guide plate down there with no rollers. The roller idler was first installed in MY83. The early idler has one roller and was changed to two rollers in 87. The rollers are often found frozen with no evidence of any ill effect on the belt. The rollers dampen vibrations of the belt between the oil pump and crank pulleys.
Hi All,
Last night I pulled the new lower idler arm assembly (Porsche part; not aftermarket) from the box and spun the roller bearing. It was "notchy" and did not spin smoothly like the original part that's 20 years old with 78k miles on it.
I do not think this is normal and I'm considering cleaning the old part and reinstalling that one.
Has anyone encountered a new "notchy" sealed roller bearing before?
Is it possible the grease settled in one area of the sealed roller from sitting on the shelf for some time?
Thanks,
Adam
Thanks,
Adam
Bill,
You make a good point.
In my engineering career we have progressed thought various stages of the maintenance of machinery.
1. Failure, repair or by replacement
2. Planned maintenace (time based strip down based on manufacturers recommendation or by in- service experience)
3. Condition monitoring
Condition 1, not recommended with the 928
Condition 2, more damaged done during strip out, inspection and replacement. than if the unit was left untouched if operating OK.
Condition 3, if it is operating within its specification and tolerances, then leave it alone except for items that are renewed on a time basis such as the timing belt, or known problems such as the headlights "E" clip inspection on the raising mechanism and the flexplate clamp on the later auto transmission cars.
Tails 1990 928 S4 Auto
Bill wrote
I did not bother to put my guide plate back on; after 150,000 KM it looked like new, never been touched by the TB _ I did not see the point of it.
Marton
HTML Code:
Marton
Under the Lift
mk
mk
Under the Lift
Hi All,
Thanks,
Adam
Thanks,
Adam
FWIW, Roger (928's R Us) informed me that you can just replace the bearings (SKF 6201) instead of the whole assembly (928.105.067.01) so I just ordered two of them (among numerous other things ).
Sounds like this isn't a big deal (i.e., maybe that roller misbehaves because it's never spun or touched), but since the replacement bearings are only $6.25 from Roger, well, might as well make it right.
Under the Lift
Replacing the bearings is certainly MUCH more cost effective than needlessly replacing the whole part which is between $135 and $250 depending on MY. Good going to Roger for recommending this alternative.
When I last did the TB on the 90GT and on the 88SE I also just replaced the bearings - sourced locally - about $5NZ each. All though I did question why I was doing it as it was plain from the even rust coating that the TB had never touched the rollers.
