Official SHARKTUNER thread
#301
Supercharged
BTW, I just realized my previous post neglects to say dropping into the 12's under boost is a very good thing!
#302
Actually, what I meant was to be able to merge the adaptation map with the base map. This would be useful because the adaptation map has the advantage of collecting lots of data over time and averaging it. Of course, when you would do the merge, you would reset the adaptation map at the same time.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#303
Agreed Jim.
BTW everyone, there is a new ST2 software Ver 6.0.6 release being field tested which sorts out the difference between LH and EZK Tenp 2 readings and also allows 4 x the size of datalogs to be run.
#304
Yes I am. It makes all the difference in the world. As soon as you hit boost, it goes into the WOT map and richens the mixture. There's no tip in or waiting for the LH the 'catch up." It should also allow for a little more aggressive timing if there is knocking caused by lack of fuel.
#306
Another question: why in the Ignition System Monitor tab in the ST app are the two air temp values always blank? At first I thought it was just my car, but all the screenshots of that tab in the ST2 manual are the same way.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
#307
I should have mentioned in the User Manual that this is an Airtemp indicator is for LH2.2 only....... the sensor in the base of the engine airfilter box.
#308
Does anyone know if the LH and EZK bin files that come with the ST2 to load the PEM's will pass emission inspections?
John,
It would be nice to have a "stock" set of maps to down load for emission inspections. Much easier than pulling the computers and swapping chips every couple of years.
When you do update the ST2 software, can you make the start logging button bigger and have a "check all" button for logged items?
John,
#309
John,
John,
Dan
'91 928GT S/C
#311
Dan
'91 928GT S/C
#312
Hi John,
The default maps are stock maps, copied from the stock EPROMS. As Dan says, if you are running closed loop, then you should have no problem at all with emmissions.
O2 loop % will not always be at zero, because of adaptation. But of copurse at idle cruise, A?F should be 14.7:1
Have added you suggestions to the list :-)
#313
I just put back the stock chips. Will monitor the AF when I take it out in the next few days.
The cruise and idle were staying in the 13's with a dip into the 12's with WOT and high RPMs.
I saw compensations from 2% up to 18%.
I won't be able to do anymore monitoring with the ST2 until the spring![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
John,
Based on my "seat of the pants" the car drove different with the PEM and your files vs. the stock chips.
Are the adaptation parameters different with your software or does it always target 14.7 in closed loop?
John,
#314
Was this a stock GT you were using for this ? If not, what is engine spec of car used ?
Clearly the A/F ratio is way out at cruise and idle, if it is running closed loop ?
There's nothing diiferent from stock chips in the ST bin files. Adaptation values do vary from car to car.
#315
Stock except for an X-pipe.
I added the cats back on for inspection and it still runs the same.
I did notice when using the non-cat, no sensor maps it was running leaner. Would see some 15's.
Would the PEM adapt differently than the stock chips? I can tell you the car runs different with the PEM vs. the stock chips. Even the first day I installed them and ran the car. I mean a good different.
I'll see what my AF look like with the GT configured 100% stock except for the wideband.
