Replacing Hood Insulation Pad
Basic Sponsor
I had dreaded doing this job because of all the mess.
I laid a tarp over the engine area and using a vacuum sucked all the nasty little particles from the hood.
Just pushed the hose end through the foam and it disappeared down the end.
No mess, no fuss and all done in 1 hour.
Hope this helps some one tackle this job with ease in the future.
Car is "Risky Biz".
Car is "Risky Biz".
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Shameful Thread Killer
So, help me understand. I drop off my car at your place, take YOUR GTS, go get a Subway, and I come back in an hour and the new mat is all done, right?
Hahahaha. Of course I wouldn't do that. I'd just stand around drinking your beer and laughing. Seriously, that looks like a nice job. My car liner is pretty hashed up, maybe I'll git-er-dun this week.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
3M makes a high temp spray adhesive that works realy well. They also make a citrus based adhesive remover that works like a charm in removing any glue residue. The remover was a life saver on getting the intake gaskets off too. And it smells nice!
Mel where did you get this 3m adhesive remover?
Do any autoparts stores that you know of carry it. Or is it something you need to get from the paint supply store?
Under the Lift
Originally Posted by MGW-Fla
3M makes a high temp spray adhesive that works realy well. They also make a citrus based adhesive remover that works like a charm in removing any glue residue. The remover was a life saver on getting the intake gaskets off too. And it smells nice!![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Two things here:
1. Do you think all old pads will come off this easily? It would seem that they would have to be at an extended level of deterioration to have the old stuff come off that easily. I had to replace the 911 variant of this a couple of years ago, and the word BEYOTCH comes to mind as I think about how hard it was to get off the old pad. For as bad as it was after 20 years of direct heat from the motor which was only 2 or 3" away in many parts, it was not an easy task to remove....
2. Be careful on the 3M adhesives. They make at least two types of contact adhesive that I know of marked for automotive use, only one is the HIGH-TEMP version.
Basic Sponsor
The factory pad already comes with adhesive on the back.
All my older cars have the same state of foam pad - crumbles when you touch it.
