What to Do With Bad Gas?
Usually Beano takes care of it. But in this case, it's eight gallons left over after draining the tank. I thought I'd be smart and run it through my lawnmower.
Yeah, so that turned out to be a bad idea; it killed a a two-year-old Honda in two gallons. So, now I have eight gallons of awful, stinky gas. It's $15 to take it to the waste dump and they keep the containers.
How do others get rid of bad petrol?
Matt
Matt
I have the same problem. About 8 gal of 5yo stale gas from my '78. It was suggested that it would evaporate from an open container over time but this sounds a little dangerous and not very friendly to the enviro/atmos.
Originally Posted by porschedog
I vote for the BBQ ignition method of disposal.
Matt
8 gallons of gas is too much to burn, IMO. I used to start fires with gas, oil and things like that, but you really only need 1 gallon or less, even for the really big brush fires...
You're just going to have to call around to all the gas stations or recycle places and find one that will let you empty your gas into one of their containers. Keep calling until you find one that won't charge you.
Matt
Matt
Hey Man
I do the same as Mark. Any bad gas I have is stored in a metal can and used for solvent in part washing/soaking. Then I mix it it with old oil for curbside pickup every 2 weeks. Eventually it's gone but it is slow. You would be surprised how soon it looses it's volatility if left out in an open wash tub in dry weather.
Originally Posted by mark anderson
We can add 10% bad gas to our waste oil for recycle.
I wish my VW Passat was still under warranty. I'd run it through there because I don't care much what happens to that piece of junk.
Thanks, Mark.
Matt
