con's and pro's of K and L-jet
Administrator - "Tyson"
Thinking of converting your cars to CIS?
right now I would choose L-jet becuase CIS parts are becomming very hard to find.
I own both & prefer L-Jet because it's easier to supercharge. I'll be converting the 79 to a 3rd party EFI before boosting.
Ljet is simpler and gets better gas mileage. The better one is the one in the car you are working on, esp. if it is working. A lot of the racer boys are taking cis OBs and doing 5.0 conversions. Seems to have the capacity for over 300 HP without too much fussing.
Official Rennlist
Borat Impersonator
Borat Impersonator
if CIS was better, Porsche would have stuck with it.
many will say that when CIS is well tuned, it runs very well and is very reliable.
IIRC CIS was used until the 90's on some MB's, Audi's etc.
I like CIS because it's so simple, there is very little that can go wrong once it's set up correctly. Borys, I guess that puts me in the "many will say" category. 3 years, 25K miles since it was last tinkered with, runs as good as ever. It seems to have better throttle response than L-Jet too.
Daniel, I'm not sure how you figure L-Jet is simpler -- there's that whole brain/O2/injector wiring/plumbing thing, and the AFM.
I am also a fan of K-jet, ONCE it is working ok. No brain to fry in the electrics, just keep clean fuel up to it, use regularly! As much or more power than L-jet, but not as economical (should not be a consideration here?). I have seen it used on Ferraris into the 90s - two units on a Testarossa. I suggest it was dropped due to failing to meet tightening emissions regs more than anything else, and the improvement in the ability to computer control injections systems.
My 83 never ceases to amaze in how well it works - from a stone cold start I can drive away with never a miss or cough or any sign of incorrect mixture.
jp 83 Euro S AT 50k
jp 83 Euro S AT 50k
If the Ljet 4.7s can make 265rwhp with the euro top end and intake hardware, they cant be all bad either![ (and support 290rwhp by adding a 5 liter bottom end) If we could find a way to open the intake by using two of the AFMs in parallel, the Ljet could work as well as CIS as far as raw power potential. that 50% restrictor plate with the Ljet has always been a thorn in my side. (well, its in Scot's side now )
mk
QUOTE=Pfunde] yeah..........[/QUOTE]
mk
Friend of mine who has been working on German cars since the early 70's has had it with CIS. Parts are impossible to find (even for VW's) and when you find them they cost a fortune.
Inventor
Ljet is pretty simple, and is easy to tune around. HOWEVER, the restictive AFM opening is a major drawback. think of it as a 50% restrictor plate !
oh yes, upgraded MSDS headers on the exhaust side with a couple of mufflers and a 3" pipe.
mk
mk
That is the key.
Didn't that setup also have upgraded exhaust?
