928 Forum 1978-1995
Sponsored by: 928 Specialists
A Replacement for a NLA Fuel Line
Old 04-05-2007, 02:52 PM
  #61
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by the flyin' scotsman
The steel braid protects the outside of the hose; can't see how there's any prevention of interior collapse......
That’s not necessarily true. The braiding also guides and keeps the hose from internally collapsing. For the hose to collapse internally, the outside would have to also deform and the braiding keeps the outside from deforming.
Imo000 is offline
Old 04-05-2007, 03:23 PM
  #62
the flyin' scotsman
the flyin' scotsman's Avatar
Originally Posted by Bill Ball
The loop that goes between the dampner and FPR is high-pressure. That's the main piece at issue in this thread. The original S4+ version appears to be a semi-rigid molded core.
One idea we're working is forming the S4+ 'U' with EFI line using an internal flexible form then solidifying the shape using a coating. The form is removed once the coating sets, the ends can be inserted and the clamps applied.
WIP
the flyin' scotsman is offline
Old 04-05-2007, 03:42 PM
  #63
H2
H2's Avatar
An engineer could verify, but I'm pretty sure that Imo000 is correct. Makes total sense.
H2 is offline
Old 04-05-2007, 03:50 PM
  #64
the flyin' scotsman
Knew I should have opted for those rubber structural courses..........damn electronics/telecom stuff got in the way
There's enough interest and folks involved Harvey I'm sure we'll get it figured.
Has anyone cut the U shaped hose open and examained it for structural make up?
Old 04-05-2007, 03:53 PM
  #65
Giovanni
Giovanni's Avatar
...solidifying the shape using a coating
What type of coating it is?
Giovanni is offline
Old 04-05-2007, 04:35 PM
  #66
BC
BC's Avatar
And why is circumventing the idiotic engineering to route the hoses this way in the first place not a good idea?
BC is offline
Old 04-05-2007, 05:15 PM
  #67
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by Sterling
Why coudnt we just have the material analyzed... for the factory construction, it looks to have a bit of a bend/shallow kink when new. I personally think the reasoning for the hose and the bend is for installation and removal. If it was a solid line, you would have to crack the bolts for the mounts to the dampners and move them outward.... it appears to be the same plastic type compound for the return line that goes over the passenger cam cover...... if we knew exactly what it was, then like everything else I bet there is a source for it. the bugger of it going to be shaping it and getting it onto the metal fittings. (sorry for the bugger reference... been hanging out with roger too much lately.... at least we have him saying Ya'll now which is humorous with an english accent)
The core appears to be the same as the passenger side line (that is the feed line, not return, BTW). That line needs flexibility to allow for engine movement. The rear loop appears to allow for some movement to make assembly easier. Since the fuel rails have rigid ends and the FPR and dampner are rigid mounted, you need to be able to move that U line around to get the connectors into the dampner and FPR fittings. They used hose on the front crossover, but not these loops probably because they needed to be molded to make the small radius. And they needed to be more than just a short hose to allow for the amount of movement they needed to accomidate engine motion and connector alignment.
Bill Ball is offline
Old 04-05-2007, 05:19 PM
  #68
H2
H2's Avatar
The orginal fuel hose, as Rog100 and others have pointed out, is a "hose within a hose"....perhaps the outer hose is to give some leeway support for bending....similar to the outer SS covering shown above?
Also, I suspect that the brass "crimp" fitting on the old hoses appears to be loose on dissection because the hose has shunk with age. I have a new hose and it's tight.
H2
H2 is offline
Old 04-05-2007, 05:52 PM
  #69
Carl Fausett
Developer
Carl Fausett's Avatar
I just wanted to make sure of something before I responded - so it has taken me a moment to find another of the "U" lines and cut it up. There is no plastic reinforcement substrate within as has been said on this post. I did not think so (I have rebuilt a coule) but just wanted to look again to be sure.
Again - there is no plastic inner liner in that U-shaped hose in any of the ones I have cut up.
Carl Fausett is offline
Old 04-05-2007, 05:58 PM
  #70
heinrich
928 Collector
heinrich's Avatar
Originally Posted by Dr. Phil
Buddy, sumthin's goin' on here ... You godda look DEEP inside your fuel hoses ... and ask yourself .... I mean what, what ... what is it exactly that we're lookin' at here .... I mean ... there's just no two ways aboudit .... You know whaddamsayin? Cause ... cause change comes from within ... I can sit here and redesign your fuel hoses for you all day ... and .... and in the end ... the answer lies with you .... It's up to YOU to become less rigid ... It's up to YOU to take the first step and become more flexible ... to GIVE a liddle ....
Yep, the man said it all
heinrich is offline
Old 04-05-2007, 06:08 PM
  #71
H2
H2's Avatar
Thanks, Carl. Perhaps my memory is bad...but I'm sure I remember someone saying that about the U-shaped hose. I have one that I've not cut up yet. However, I KNOW that one of the fuel hoses on my 968 had a hose within a hose covering. Debate as to the function of the second hose covering. Protection for the inner hose or?
Either way, it doesn't matter to me as long as a suitable substitution is found.
Harvey
H2 is offline
Old 04-05-2007, 08:11 PM
  #72
the flyin' scotsman
Carl...........with all due respect the U fuel line pictures in your web site is of an older model of car. The S4 and up cars have a similar U shaped line but its a tighter U hence much of this discussion.
Perhaps for absolute clarity Roger or Heinrich who have multiple models could post some pics.
Old 04-05-2007, 08:24 PM
  #73
DR
Rennlist Sponsor
DR's Avatar
85-86 on left, 87-up on right
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
DR is online now
Old 04-05-2007, 08:26 PM
  #74
the flyin' scotsman
Thx Dave...........now how do we build the version on the right?
Or.......can we use the 85-86 version on newer cars; seems like they'd be easier to replicate.
Last edited by the flyin' scotsman; 04-05-2007 at 08:30 PM. Reason: another thought?
Old 04-05-2007, 08:35 PM
  #75
sharkmeister85
sharkmeister85's Avatar
That may be the case. The one that came off of my '85 has a plastic inner liner. Well, unless its something else.
Glenn
sharkmeister85 is offline
Quick Reply: A Replacement for a NLA Fuel Line
