928 Forum 1978-1995
Sponsored by: 928 Specialists
GAS TANK LEAK
Old Mar 24, 2007 | 01:57 AM
bigrob's Avatar
bigrob
Default GAS TANK LEAK
I spoke of this before but have a question. My tank is leaking from the lower of the two venting outlets. When I address this, can I just plug the lower & upper connections? I am thinking that getting the fuel line back through the chassis for reinstallation may be difficult!
What do ya think? Thanks!
Old Mar 24, 2007 | 02:51 AM
Optimator's Avatar
Optimator
Not sure what you are asking. Are you thinking of just capping the two connections and not reinsalling the hose? If you want to be able to get more than about 5 gallons or so in the tank, the bottom connection needs to be vented. Otherwise, most of the tank will be filled with trapped air, due to the U-shape of the tank. Dave A. has a nice guide on doing the gas tank, where he describes a good procedure for connecting the new hose when you reinstall the tank. Look here:
http://members.rennlist.com/sharkski...0-FuelTank.htm
Old Mar 24, 2007 | 11:16 AM
bigrob's Avatar
bigrob
Just what I was wanting to know! Thanks so much for the procedure!!
Old Mar 24, 2007 | 04:10 PM
SharkSkin's Avatar
SharkSkin
Optimator beat me to it. BTW, my cautions about breaking/scoring the nipples on the tank are worth repeating. I didn't score or break mine, but by the time I did this project myself I had heard enough horror stories about them breaking that I was able to avoid that pitfall. Also, I have removed fuel lines from plastic barbs on other vehicles in the past with a utility knife, only to find I had fubar'ed the barb.
Old Mar 24, 2007 | 05:38 PM
Optimator's Avatar
Optimator
The advice about damaging the barb fittings definitely warrants extra emphasis. Those polyethylene barb fittings are VERY soft, and it is very easy to accidentally gouge or scratch them. I suggest cutting half way through the hose wall in several places to weaken it, and then carefully push the hose off with a pair of lock ring pliers inserted between the hose end and the side of the barb fitting.
When removing the tank I had to cut the large vent hose in two places. The only tool I had that could reach into the confined areas was a small hack saw (the type that is basically just a handle attached to one end of a standard hack saw blade). On my car someone had already had the tank out before, and they replaced the 15mm vent hose with heater hose. Don't use heater hose! It cannot withstand constant exposure to oil or gasoline. Furthermore, they had installed it with a kink, which made it non-functional.
Old Mar 24, 2007 | 06:01 PM
SharkSkin's Avatar
SharkSkin
Not at all -- It's there to share & "give back" to the rennlist community. I'm glad people find it useful enough to point others to it!
Old Mar 24, 2007 | 06:19 PM
jon928se's Avatar
jon928se
Getting the hose back on isn't that tricky. Insert hose through hole in chassis. Wriggle tank back up in to place supporting it with a floor jack (for control not for force) when tank is abou 6" lower than it's final resting place reconnect the vent hose to the top of the tank - attack it from the drivers side rear wheel well reaching undr the chassis rail and over the top of the tank. As you then raise the tank into position pull the excess slack in the vent hose through the chassis rail. When tank in place reconnect to the top ven position again from the wheel well. Tighten the pipe clamp on the top vent access through the fuel filler flap.
Old Mar 24, 2007 | 11:55 PM
bigrob's Avatar
bigrob
You guys ROCK!! Thanks! Although My MM's are getting done this week! The tanks is a little more down the road, but will be getting done!!
Grazie!
