928 Forum 1978-1995
Sponsored by: 928 Specialists
How do you remove/disassemble the hatch upper latch? Now - Hatch rattle fix.
Old 07-01-2012, 01:03 PM
  #76
nexty226
nexty226's Avatar
Originally Posted by Bill Ball
So, is your conclusion that you cannot just swap the alarm components into a non-alarm housing?
No , when you finish with the dremel tool, you'll then have a very thin pice and it will crack on the first time you close the back lid
Old 07-01-2012, 01:16 PM
  #77
Bill Ball
Under the Lift
Bill Ball's Avatar
Argh.
Old 07-01-2012, 01:23 PM
  #78
nexty226
nexty226's Avatar
That's too bad. I would liked to give you good news, sorry mate...
Old 07-01-2012, 01:27 PM
  #79
fraggle
fraggle's Avatar
Good news but sad I suppose.
Need that cnc solution!!!
Old 07-01-2012, 01:33 PM
  #80
nexty226
nexty226's Avatar
I had to change mine (broken) with a car that was litler bit more good than mine, but now I don't have a core to try to make it un my cnc. Im using the shark so for now I can't take it off to measure it and trying. Someone have a broken one? So I could put me mind to it and make it.
Old 07-05-2012, 02:10 PM
  #81
Bilal928S4
Bilal928S4's Avatar
Default Alarm vs non alarm latch
So yesterday I decided to work on my upper latch for the hatch. Here are some pictures of the differences of the allarm version vs non alarm version. The casting of the body is quite different and it does not seem possible to put the guts of the alarm version into the non alarm version.
Old 07-05-2012, 02:15 PM
  #82
Bilal928S4
Bilal928S4's Avatar
I installed the non alarm version from Roger. Thanks Roger. The only difference is that you have to use the new key to open the hatch and that the alarm will not be unarmed. So if the car is locked and the alarm is armed (usually it arms automatically when you lock the car), when you open the hatch the alarm goes off.
The squeeking of the hatch has been totally eliminated.
However, I cannot get my hatch to open remotely with the switch on the side of the seat.
Old 07-05-2012, 02:20 PM
  #83
Bilal928S4
Bilal928S4's Avatar
Default Remote hatch release
The motor for the release cycles through the entire range. The bottom hatch bar moves through its 90 degree motion but does not release the upper hatch. I tried it manually and with the motor in place and it looks like the bar does not protude enough into the 'hole' to release the white part. Both the new and old upper hatch latch did not work.
Old 07-05-2012, 02:28 PM
  #84
Bilal928S4
Bilal928S4's Avatar
Old 07-05-2012, 07:45 PM
  #85
nexty226
nexty226's Avatar
Thas's why we can't use the non alarm version. Hey what are your planing to do with the alarm housing that you have?
Old 07-05-2012, 08:18 PM
  #86
Bill Ball
Under the Lift
Bill Ball's Avatar
Bilal:
Thanks for the clear exposé on the differences between the alarm and non-alarm upper latch housings. That nails that question down.
As to your release issues, one solution Alan came up with is to put several tie wraps around that bar to help it push the tongue enough to release the hatch.
Old 07-05-2012, 09:21 PM
  #87
Bilal928S4
Bilal928S4's Avatar
Bill,
I had done that trick and it worked with the original latch until, as you can see in the pictures, it cracked completely on one side. But I do not see any wear on the release bar or on the lower housing. So after I put the new latch in, I expected it to work properly.
I guess now I have to replace the bottom one also.
Old 07-05-2012, 09:26 PM
  #88
Bilal928S4
Bilal928S4's Avatar
Nexty226,
I was waiting for somebody to manufacture a housing so that I could transfer all the innards from my original one into it.
I can lend it to you for prototyping, but need assurance that I will get it back as it is keyed to the rest of my locks.
Old 07-06-2012, 04:55 AM
  #89
Bill Ball
Under the Lift
Bill Ball's Avatar
Bilal: I'm not sure why the bottom end is not working. The metal bar should not wear and I think the tie wrap fix was to compensate for wear on the other parts. Perhaps it's a positioning problem - there is a little play in the mounting of the parts that might have some effect. I haven't had to deal with that.
Old 07-06-2012, 08:28 AM
  #90
nexty226
nexty226's Avatar
Bilal I will send it to you exactly as it is, and my promise that when I have done the drawings, mail it to you the same day. Of course there will be a discount from mu part on the pice ;-)
Quick Reply: How do you remove/disassemble the hatch upper latch? Now - Hatch rattle fix.
