Under Driver's Side Fender, what are these?
In one foto, there is the splash panel on the driver's side with a securing bracket, apparently for securing something ...but nothings' in them..and I can't find them on the PET. They must serve some purpose. Any idea?
In the second foto, coming front, there are two small yellow wires in a gray sheath, going into a connector, the extending a few inches before being capped. Any idea what this is for? There is nothing similar on the other side.
Thanks.
Harvey
Thanks.
Harvey
Under the Lift
Answered in other thread...
https://rennlist.com/forums/928-forum/334180-nicole-s-y-connector-will-help-avoid-cutting-wrist.html
I see you moved it now.
https://rennlist.com/forums/showthread.php?t=334180
You seem to be missing the air intake hose for the alternator. On the end there is a loop of hose held by that bracket. The wire you have there is the outside temperature thermistor for the climate control. It usually is inserted into a metal section that is part of of the alternator air intake hose, just before the final end loop.
The way to install the hose in the bracket is to detach the hose end from the alternator and pull some slack into the fender area. Once the hose is set in the bracket and the liner piece is reinstalled in the wheel well, pull the slack back out and reattach the other end to the alternator. I did it the hard way the first few times.
Comments by Bill Ball
Originally Posted by the flyin' scotsman
Was the car in an accident to have those pieces removed?
How does the HVAC system work with no O/S temp sensor?
Harvey
The HVAC will function, but if I’m not mistaken the controller will think it's really cold outside. When mine was disconnected and I had to slide the temp selector to the far left before it would work. Now that it's reconnected, the A/C works in other positions.
Following are some pictures of the alternator cooling duct I think you are missing. Mine had a hole in it and I guess some critter decided to make a nest in there.
Under the Lift
Originally Posted by auzivision
The wires go to missing outside air temp sensor. The bracket I believe is to hold the missing alternator cooling air duct, which houses the temp sensor.
Under the Lift
Originally Posted by Hughett
This is a good question, is the temp sensor even required? On my '94 968, I have a temperature gauge that reads outside temperature and displays it. No such display in my '88 928. But if not having a temp sensor will effect the cars function or HVAC, I'd better get one, eh?
Harvey
Harvey
Well, it looks like I'm in the market for an Outside Temperature Sensor. Used works for me. Anyon have an extra laying around?
Harvey
Harvey
