Anyone ever removed the rear AC in a 91' $4?
7th Gear
I'm restoring my tired interior and am going to do a rear seat delete and am wondering why I should keep the rear AC that I haven't used in 8 years. What problems should I anticipate? (I've had this fine auto long enough to know that there will be problems). BTW this is my first post on this forum although I've read it over the years. Thanks!
____________________________________
formerly:
61' Austin Healey 3000 MkII
65' Austin Healey 3000 MkIII
64' Jaguar E-type Roadster
71' Jaguar E-type Coupe
76' Datsun 260z Coupe
77' Datsun 260z 2+2
87' Porsche 944
NOW
91' $4-auto, Black/marble grey - 18"carreraIII
02' Audi TT Quattro 5sp - Silver/Black
03' BMW 325 CI Coupe 5sp/Sport pkg - Silver/Black
formerly:
77' Datsun 260z 2+2
87' Porsche 944
NOW
Drive it over to me...I'd do the take out for the parts as I want to install rear air in my '79 as I'm doing a interior redo soon.If thats not an option how much would you want for all of the inside parts and lines that go up into the engine compartment??
Rear air can be removed, but you need to discharge the system first and suck it all out. The main two AC lines have a branch that is jointed right underneath the fuse/relay panel underneath the car. These need to be capped off right there, otherwise the oil will pool there. Louie did this I think while the lines while they were on the car.
There will be a 3 inch hole in your passenger rear footwell when you are done.
Inventor
Oh, snap! I think I remember hearing this, long ago, about not disconnecting at the fitting under the passenger seat. My rear air was removed at some point, and capped under the seat. I wonder if my (original) compressor has any oil in it?
I have most of the parts to restore the rear air, but I would like to find someone who has an R12 evacuator, so I can save my old 'chill'.
I bet you already know this, but with the A/C season just around the corner there will be lots of questions by the newbys who have taken ownership in the last hear. So for clarification, I've never heard the term "evacuator"; methinks that would describe a vacuum pump, which does not save "chill". A vacuum pump is jut that, it will pull a vacuum and dump whatever is in the lines into the great open air. To save refrigerant and dry it for future use would require a recycling station.
Right on, I'll be subscribing to this post. I'm that dang newbie who'll be asking all kinds of rear A/C funny questions such as: why didn't they just run some skinny vents to the rear via a 3" raised center console? No, really. Can anyone point me to a good write-up of someone who's refurb'd their rear A/C?
7th Gear
To BrendanC and Sterling thanks for the info!, 928FIXER when it gets yanked, I'll let you know.
PorKen,SteveG and LaufenOutLoudI appreciate your comments.
If you lived in California you'd keep the rear ac.
