928 Forum 1978-1995
Sponsored by: 928 Specialists
Is there room for improvement on the Euro S cam?
Old 02-04-2007, 05:52 AM
  #61
scott863
scott863's Avatar
[QUOTE=mark kibort]dangler, as i said, I probably have the most experience in pushing the 4.7 in stock form, 4.7 in part euro form with the euro cams and the 5 liter part euro 2 valve, as well as the S4 5 liter.
from racing and the dyno runs performed, it looks like this:
4.7 stock US flat feeling 200rwhp and 245rwt
4.7 US with euro intake and euro cam, peppy feeling 246rwhp and 245rwt ( so no trade offs for the cams, just 45hp gained!)
Mark, for euro intake are we talking euro 85-86 intake runners and euro throttle body, or just throttle body?
Old 02-04-2007, 06:04 AM
  #62
danglerb
danglerb's Avatar
AFAIK at least Elgin, Web, and John Milledge may have cam options for the 928 16v, but I haven't tried talking to Elgin yet, Milledge hasn't asnwered emails, and I haven't decided on pursuing Web.
Raw cam numbers don't make sense to me without the reason for the variation, could be something that doesn't apply to what I want, like not wanting to cut relief's in the pistons.
Old 02-04-2007, 07:43 AM
  #63
John Veninger
John Veninger's Avatar
Not building a hybrid motor now?
Old 02-04-2007, 08:35 AM
  #64
danglerb
danglerb's Avatar
Originally Posted by John Veninger
My assumption was that "Eglin" wasn't targeting the cam to a hybrid and may have restricted the cam design to lift that didn't require pulling the motor and cutting pistons.
Nothing has changed in my own plans, which depend on what parts etc. I find.
Each day I poke around for more details on the hybrid motor in old posts, search for parts and parts cars, and look at any newer cars on the market as well.
Old 02-04-2007, 08:44 AM
  #65
John Veninger
Elgin has no idea about a "hybrid" motor.
Old 02-04-2007, 07:31 PM
  #66
danglerb
danglerb's Avatar
If someone went to Elgin and asked for a cam and said they were willing to cut relief's in the pistons, he might provide one with higher total lift.
My point is that looking at someone else's custom cam spec without the reasoning behind it, may not be the most useful course.
Old 02-04-2007, 07:41 PM
  #67
John Veninger
Good luck talking to Elgin.
Old 02-05-2007, 01:29 AM
  #68
mark kibort
mark kibort's Avatar
euro runners, plennum and throttle body, with the US "U" hogged out too.
Mk
[QUOTE=scott863]
Old 02-05-2007, 01:36 AM
  #69
mark kibort
in looking at the valve cut outs, i noticed that they are really not that deep. you could use a air tool and grind them yourself. i traced the two pistons and its accurate to about .5mm. now, if you want to trace the valve cuts and do them yourself, you could. actually, the first pass on my first 5 liter euro, showed the pistons hitting the valves when they were pressed down .5". ( we clayed the pistons) so, i to an air grinder and make the smilie faces about 2mm wider all the way around. they didnt look as nice as the pro-machining work, but who cares, it worked! somehow the set up wasnt exactly perfect at the machine shop.
anyway, with a 5 liter short block, all you need to do is re ring, re bearing and put it all together after you notch the pistons. not a bad job and you get a new motor in the end!
Mk
Quick Reply: Is there room for improvement on the Euro S cam?
