928 Forum 1978-1995
Sponsored by: 928 Specialists
Radiator end caps - Gotcha!
Old Jan 29, 2007 | 12:01 PM
heinrich's Avatar
heinrich
928 Collector
Yes Jim, I think the silver bullet of radiators is the elusive dream. Unfortunately we just don't have one. But your rad looks like a great option. I've used all sorts of radiators and I've had Behr brand new leak, and other Behrs last the life of the car. It's a crap shoot.
Old Jan 29, 2007 | 12:02 PM
ROG100's Avatar
ROG100
Basic Sponsor
Jim,
I love the idea of the complete aluminium rad.
I did post this question on another thread.
I have heard of a number of aluminium rads leaking (from another supplier) and wanted to know your and Mark's thoughts on why your rad will not leak.
What length of warranty is on the 928 Int rad
Old Jan 29, 2007 | 12:51 PM
Mark Anderson's Avatar
Mark Anderson
The Parts Whisperer
Originally Posted by ROG100
Jim,
The radiator we offer is made by C&R and they oven braze their end tanks to the core. Other manufactures epoxy theirs together and I think you will find that is where they leak which may also be why they only offer a 90 day warranty. The C&R comes with a 1 year warranty.
http://www.crracing.com/radiators/cu...adiators.shtml
Old Jan 29, 2007 | 01:03 PM
ROG100's Avatar
ROG100
Basic Sponsor
Mark,
Thanks for the update.
The next time I need a rad I am buying yours.
Never had anything fro 928Int thats given me a problem.
Roger
Old Jan 29, 2007 | 01:16 PM
Leslie 928 S2's Avatar
Leslie 928 S2
Hi Roger!
Kevin bought International's aluminum radiator for his s/c'd automatic last August. It went in without a hitch, cools MUCH better than the stock one, and so far no signs of leaks anywhere. It's welded extremely well, and we are both very happy with how it looks and how it performs. Honestly, it's so well made I don't see how it could ever leak. We are a couple of very happy customers.
You won't be sorry if you ever need to go this route.
Best,
Leslie
Old Jan 29, 2007 | 01:23 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
I don't remember those tabs being on the sidetank when I got it from 928Intl about 2 years ago. Memory fade vs. part has changed vs. Jim cut it off.
Old Jan 30, 2007 | 11:06 AM
ROG100's Avatar
ROG100
Basic Sponsor
I used a Dremel to remove the bracket - very easy to do.
I had to remove the radiator to do it as it was not that easy while installed in the car.
A note supplied with the caps would have saved a lot of time and effort!
Old Jan 30, 2007 | 03:40 PM
docmirror's Avatar
docmirror
Shameful Thread Killer
I gave Rog an end tank last week, and I don't think it had tabs on it?
Another note on end tanks like these. I have successfully exchanged end tanks on this style using a 2X4 wood cradle to support both sides of the rad flange, then one more 2X4 set on top of the end tank. The whole asm was pulled together with a few black bungees on each end, although I would probably use a eye bolt and nut in the future to draw the tank down on the flange.
The trick is to keep even, solid force on the end tank all along the flange where the tabs are. Once you've got that, use a water pump plier to bend the tabs inward first, then pinch over the edge of the end tank.
Doc
Old Jan 30, 2007 | 03:58 PM
Jim bailey - 928 International's Avatar
Correct the key is NOT trying to use the metal tabs to pull the end tank seal into place. Some type of clamping device takes the tension off the tabs so they can be unbent ONCE then after the new tank is compressed in place as Doc says bend back into place ONCE to secure the tank in place. Since you only get one repair on most of these radiators it is advisable to always install a new tank even if it is only a seal leaking...because the plastic tank is going to crack eventually.
Old Jan 30, 2007 | 04:25 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Doc:
"Water pump plier" ??
Old Jan 30, 2007 | 05:12 PM
ROG100's Avatar
ROG100
Basic Sponsor
Doc,
Your end cap has the bracket as well.
Roger
Old Jan 30, 2007 | 05:18 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Water pump plier = big *** channel-locks (?)
Old Jan 30, 2007 | 06:22 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
On which part of the water pump are they used?
Old Jan 30, 2007 | 06:24 PM
Rob Edwards
Archive Gatekeeper
Good question, I'm sure there's an interesting etymology /tool-ology lesson here. I just googled water pump pliers and came up with some pics that looked like Channelocks....
Old Jan 30, 2007 | 11:11 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Back in olden times, the water pumps had adjustable packing nuts and rope packing, instead of rubber lip seals. The packing nuts had to be tightened occasionally, and since the applied torque was very low, the water pump pliers were the tool of choice...
