928 Forum 1978-1995
Sponsored by: 928 Specialists
Intake Manifold Spacers that Increase Torque...Do they still exist?
Old 01-18-2007, 02:14 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Default Intake Manifold Spacers that Increase Torque...Do they still exist?
A while back I heard about someone developing some sort of shim that goes in between the side intake manifold covers. A gain in torque was a result of the shim upgrade due to the increase in air volume in the intake plenum. Do these still exist? Who makes them?
Old 01-18-2007, 02:29 PM
hinchcliffe
hinchcliffe's Avatar
I've heard of the TB spacers (mostly depending on the car thedo nothing), but not Manifold spacers?
Old 01-18-2007, 02:54 PM
PorKen
Inventor
PorKen's Avatar
Hmmmn... I wonder what would happen if you put longer manifold hoses on an '85-'86? Variable length?
Old 01-18-2007, 03:04 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
It would act as the S4-up spacer. The small tubes can be replaced with sections of 2" rad hose. The 2 large ones probalby have to be special ordered.
Old 01-18-2007, 03:58 PM
Vilhuer
Vilhuer's Avatar
I think about 8mm thick spacers are thickest which will fit before side plates get too close to fuel rails. They should help on stroker top end hp as they allow easier air flow. Will not do much if anything on 5.0L.
Old 01-18-2007, 05:55 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
Thanks for the replies. All I needed to know!
Old 01-18-2007, 06:23 PM
Larry Velk
Larry Velk's Avatar
Don't know if this file will attach. Old-timers may rem. these.
Old 01-18-2007, 06:26 PM
aggravation
aggravation's Avatar
Is that something that allows you to attach a pair of Holly four barrel carbs to the intake?!?
Old 01-18-2007, 06:35 PM
Larry Velk
Larry Velk's Avatar
That was the first version of MoPar "Ramcharger" intakes. I believe first used on 383's. It was replaced by a more compact design.
I'm sorry if some thought it was for a 928! You were all excited that an even stranger manifold than the one on '85'/'86's was avail.
The cast iron exhaust on these cars was equally cool - they were rectangular and very intricate. I'm not a MoPar expert (was into Fords in the early 60's), but the castings were fast looking!
Old 01-18-2007, 08:45 PM
6.0-928S
6.0-928S's Avatar
I'm sorry if some thought it was for a 928! You were all excited that an even stranger manifold than the on on '85'/'86's was avail.
I don't know if you've ever ridden in one of these cars, but those manifolds WORKED! Here's the shorter racing version,
Hammer
Old 01-18-2007, 09:39 PM
neilh
neilh's Avatar
Hammer
Hammer not often you see a nice piece of hardware like that sitting on the carpet inside the house!
Although I did have one friend who had a Snap-On tool box as a piece of furniture, and two Harleys sitting in the sunken well of his family room.
Old 01-18-2007, 10:13 PM
Dennis Wilson
Dennis Wilson's Avatar
IIRC that manifold was first used on the 426 and the carbs were Carter AFB's.
Dennis
Showing my age
Old 01-19-2007, 12:35 AM
SharkSkin
SharkSkin's Avatar
I thought those were the cross-ram first used on the 413 Wedge... My Mopar lore is fading these days though.
Old 01-19-2007, 01:06 AM
danglerb
danglerb's Avatar
What are the spacers for? Typically its just to keep heat out of the intake isn't it?
Old 01-19-2007, 09:25 AM
drnick
drnick's Avatar
i think alex is still working on these..
Quick Reply: Intake Manifold Spacers that Increase Torque...Do they still exist?
