Zimmerman Brake Rotors Question
Just picked up a new set of Zimmerman's for my '89...should these be turned before installing? They look like they are ready to go, but just wanted to check what others have experienced in the past.
Glenn
Glenn
Should be good to go once you clean them...........rotors typically have a rust prevention coating on them from the factory.
Paint the hats as they'll rust pretty much right away. We've had good luck here in DFW land using rustoleum "Hammered" paint. It comes in black, charcoal, and silver. Looks awesome and at least 4 of us have used it with great results. Spray or brush on it comes out good either way.
Supercharged
Originally Posted by Bill Ball
The wear limit spec for our rotors is 2mm total...that's only 1mm per side. When the lip reaches 1mm, time for new rotors.
