KEMPF TOOL ? If thats the name need instructions
JUST RECIVED MY TIMING BELT ADJ TOOL:
The instructions are washed out and hard to read, anyone know how to use one of these or has a good picture of it in place. I want to test my old belt before it comes off to know what to look for!
Originally Posted by Tampa 928s
I can wait
Have you used it, any tricks to it? i just thought its a good idea to get a base line.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
For sure, follow the directions, but basically, you slot the gauge between teeth on the TB halfway between where it hits the pass-side cam and the tensioner roller. Make sure it is seated as deep as it can go onto the belt. Have it so the spring is facing the passenger side of the car and then twist up. The spring-loaded gauge will move into the notched window on the tool (if the belt is correctly tensioned). If the edge of the gauge doesn't make it to the window, the belt is too loose. If it goes past the window, your belt is too tight.
With the new belt, you need to test many times (which will make you an expert at it). Test when the engine is at TDC, crank a few rotations, test again and so on. Adjust the tensioner and crank some more to allow the tension to be distributed across the belt length.
If nobody else is able to get you the instructions, let me know and I will scan mine.
Matt
Thats a very old 928. May need more then a belt.
The instructions are washed out and hard to read, anyone know how to use one of these or has a good picture of it in place. I want to test my old belt before it comes off to know what to look for!![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Originally Posted by SharkSkin
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
