928 Forum 1978-1995
Sponsored by: 928 Specialists
Starting my TB change
Old Dec 29, 2006 | 07:07 PM
Tampa 928s's Avatar
Tampa 928s
Default Starting my TB change
Wish me luck
Old Dec 29, 2006 | 09:48 PM
Mike Frye's Avatar
Mike Frye
Craic Head
Go Tampa. We'll be watching from the sidelines.
Old Dec 29, 2006 | 09:56 PM
heinrich's Avatar
heinrich
928 Collector
Get Mel, Ceedee, DonBMini, Fabio and others to hang out, have a beer and assist.
Old Dec 29, 2006 | 10:17 PM
Ed Hughes's Avatar
Ed Hughes
Good luck! Take your time, and use the Pirtle checklist (there are a couple of errors, but common sense will tell you what to do-they're insignificant), you'll be fine.
Old Dec 29, 2006 | 11:43 PM
Shark Attack's Avatar
Shark Attack
I was all nervous too when i did mine a few weeks ago... Its a lot easier than everyone makes it sound. Its kinda overwhelming at first becasue of all the suff coming off the car... I had hardly anyparts leftover. what is your parts and tools check list?
Old Dec 29, 2006 | 11:50 PM
Tom928's Avatar
Tom928
Well said. The only thing I would add is to take alot of pictures with your digital camera.
Old Dec 30, 2006 | 12:03 AM
Ed Hughes's Avatar
Ed Hughes
I don't think the prevaling thought is that this is a horrible job. It does take some time because there are so many steps, but if you follow John Pirtle's excellent instructions and checklist as I mentioned above, and work carefully and methodically, it is pretty straight-forward. I had not one leftover bolt or part....
The only thing I would change next time, is that I would spread the job over two days instead of one. 8 hours of non-stop bending over a 928 motor is too much for my back to handle. It does consume time, so be prepared to spend it.
Old Dec 30, 2006 | 01:07 AM
WICruiser's Avatar
WICruiser
I agree with the sentiment already stated above. It can seem to be an intimidating job given all of the parts coming off, steps in the process, etc. but it is basically not difficult just time consuming and the guides discussed and this group as a backup should provide everything you need.
Old Dec 30, 2006 | 01:10 AM
heinrich's Avatar
heinrich
928 Collector
let me offer the best advice I can.
remove your radiator
Old Dec 30, 2006 | 03:28 AM
SharkSkin's Avatar
SharkSkin
I'm in the middle of this myself, having just started today. I meant to start last Saturday, but Xmas, family, etc. has delayed it. Worst part was watching my Craftsman 1/2" long-handle ratchet flex like a piece of taffy when I put an extender on it for leverage. Burned up some of my day getting a serious breaker bar. Other than that, it's all just nuts & bolts...
Old Dec 30, 2006 | 08:32 AM
Tampa 928s's Avatar
Tampa 928s
Default Feedback !
I have every tool I think i need and I started last night. I removed the Alt belt and started on the Air belt but I quite after I could not move the unit enough to slip the belt off. I like the Rad removal idea as said the rest is nuts and bolts. I am taking lots of pictures, plus baggies and a marker on each item removed.
I did not find a good write up on all the little things to remove so i hope I'm going at this in the correct order.
Old Dec 30, 2006 | 08:38 AM
Ed Hughes's Avatar
Ed Hughes
Tampa: I had the same issue, the last 2 belts stayed on until I removed the crank pulley. Trust me, it works. Don't stress on getting the belts all of individually.
Old Dec 30, 2006 | 09:24 AM
oups59's Avatar
oups59
It is not that bad. Take your time.
Old Dec 30, 2006 | 11:02 AM
UKKid35's Avatar
UKKid35
If you don't want to remove the rad, which will still leave the aircon condenser anyway, use a piece of hardboard cut to size to protect it, or at least a piece of cardboard.
Old Dec 30, 2006 | 11:34 AM
marton's Avatar
marton
HTML Code:
Some people say it is time to fit new belts anyway so simply cut off the old ones.
Marton
