928 Forum 1978-1995
Sponsored by: 928 Specialists
Metric Thread chaser set
Old 12-25-2006, 10:40 PM
GUMBALL
GUMBALL's Avatar
You are correct. I guess that I didn't explain it properly. Thank you.
Old 12-25-2006, 11:55 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by GUMBALL
A tap or die is made to cut new threads, where a thread chaser is made to clean/repair/straighten existing threads. A thread chaser will not cut new threads, therefore, it will not "over-cut" and damage the part. Using a tap or die on existing threads can cause damage.
Hmmmm.. This is news to me. I've alway used either a tap or a die to clean, straighten, and to cut new treads. Never had a problem using them and never even knew there was a seperate chaser set.
Old 12-26-2006, 12:44 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Well, here's what Two Guys had to say:
"Before installing new fasteners into an engine, clean the threads in the holes using a thread-cleaning chaser.
Don't mistake the thread-cleaning chaser for a traditional thread cutting tap. The chasers are strictly used as cleaning taps, not to cut threads, and are designed with the correct thread pitch and diameter to clean dirty blind or thru holes without causing thread damage. A set of cleaning taps is an essential tool to a serious engine builder."
Old 12-26-2006, 12:51 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
They must be something like a pre-dulled taps and dies, right? I can see how taps/dies can cause damage if not used properly. They need to be backed 1/2 a turn every now and then or else the built up of removed metal will damage the treads. Also using lubridants during tap/die use is a must.
Old 12-26-2006, 12:57 AM
ZEUS+
ZEUS+'s Avatar
Bill is correct. I have a complete set of each. Thread chasers are made slightly smaller to clean debris without damage.
Old 12-28-2006, 09:10 PM
BC
BC's Avatar
I need to get some chasers. Snap on site is not search-Friendly. A snap on guy drives by my office every few days though. Maybe I can run out in the road infront of him and flag him down. Call my wife if you don't hear from me.
Old 12-28-2006, 10:45 PM
FlyingDog
FlyingDog's Avatar
I picked up a set of metric thread chasers from McMaster-Carr recently. I've only used the 14.5x1.5 to clean wheel studs, but worked very well. ~$35 for I think 12 external thread chasers and a file or two.
Old 12-29-2006, 12:02 PM
checkmate1996
checkmate1996's Avatar
What part numbers?
Old 12-29-2006, 02:20 PM
FlyingDog
FlyingDog's Avatar
2616A22
If you go to the thread chaser page it's the last one on the bottom. $31.88.
Old 12-29-2006, 02:35 PM
RyanPerrella
RyanPerrella's Avatar
Check Sears catalog. They have a 40 peice SAE and metric interior and exterior thread chaser with files for $39.00.
I am going to go to the local sears and see if they have them on hand, otherwise I will order it online.
The price is supposed to be valid til 12/30/06 so get your orders in now if your interested.
Old 12-29-2006, 03:42 PM
SharkSkin
SharkSkin's Avatar
I just went to sears.com and they also have a 48-piece set for the same price, item 00942275000.
Old 12-29-2006, 04:07 PM
BC
BC's Avatar
I see it dave. Is this the best for all the sized we need on the 928 do you think? Because I need a set soon.
Old 12-29-2006, 04:11 PM
BC
BC's Avatar
Looks the same as this, but better and cheaper:
http://cgi.ebay.com/ebaymotors/Kasta...QQcmdZViewItem
Old 12-29-2006, 04:12 PM
BC
BC's Avatar
Here is a close up of a snap-on version (but again looks similar)
Old 12-29-2006, 04:13 PM
BC
BC's Avatar
I am concerned that the size required to clean the threads of the head stud holes is too big to fit down there?
Quick Reply: Metric Thread chaser set
