gasket - worst luck
Originally Posted by the flyin' scotsman
Steve...........where is the smoke coming from under the hood?............is it indeed smoke or steam? does it smell sweet?
thanks
Originally Posted by ZEUS+
How long did you run it for ? Is the smoke thick ? Has coolant level gone down ? What is the temp. out there ? Sorry about all the questions.
around 5 to 10 minutes, smoke is thick, not sure about coolent level but i did smell it, and temp seemed normal.
Originally Posted by juvius
smoke is coming from both under the hood and the exhaust.
thanks
thanks
I have always put 9 in both of mine for the past twelve or so years.
Sorry for the bum steer, Juvius.
Can you be more specific as to where under the hood? What is the outside temp?
thanks
Originally Posted by Bill Swift
9 quarts is fine.
Steve, how was the engine prior to the oil change?
Not having an overheat condition it becomes misleading. I hope it is a split hose somewhere, but the smoke out the tailpipe is bothersome. How does it run ?
So the weather's not cold enough to effect the coolant freezing.
Strange it would just happen after the oil change; did you jack up the car and possibly spill anti-freeze out the reservoir?
Doing a pressure test of the cylinders should reveal a leaky head gskt if thats what you have.
