bottom of the 9th panic attacks (TB ISSUE,79 euro)
I am sitting here thinking about the tentioner roller and how it is not centered on the belt.. Did i forget to put the spacer back in behind the arm???? I already have the cover on and all te parts back on that have to come off to get to it.
does anyone have a pix of a tentioner roller on the belt?
thanks
Kyle
thanks
Kyle
Be careful, but don't sweat it too hard. Let me find my old thread about my tensioner...
My weird-*** tensioner thread
If the tensioner is set to the proper tension, I would think that after a few rotations, the belt would center itself to a point. If the belt is too loose, I would think it would roll outward that way.
Of course, I don't actually know what I'm talking about, just guessing that the belt would behave this way.
Originally Posted by PorKen
How many times have you rotated the engine by hand?
Until you run the engine for a few seconds to settle the belt, it may track wherever it wants.
JP,
What's up with that bastard front pulley?
JP,
Originally Posted by Shark Attack
I forgot to put the spring clip on the back side of the roller when i replaced the roller.
Matt
Is your tensioner dry? You mentioned previously that you didn't do anything to it when you were in there. My belt was riding about 1/4" off of that same roller and the only thing that was not right about the whole set-up is that the tensioner was dry and the tensioner boot was hard as a rock, and cracked. The belt had just barely started grazing the Tensioner Arm and luckily the bolt wasn't bent yet.
Also, if you haven't been able to check the tension yet, maybe the belt is too tight?
