Water Pump Bolt Troubles
#33
Hey guys,
I need a little more help. The belt tensioning took came in today, so I figured I will put the car back together tonight. We'll I figured wrong. I stripped three water pump threads tonight trying to torque it to 6 ft lbs. The threads from the inside of the block came off before I can reach 6 ft lbs. What do I have to do now? Is there such a bolt that I can screw into the block and it will expand to hold the water pump to the block? Please help, I'm tired of driving my wife's car.
#41
Originally Posted by T Colvin
Hey guys,
Spec is 6 Nm, which is about 4.43 foot pounds. You're much better off using a wrench that reads in inch pounds since there are few if any torque wrenches that are accurate at this torque if they are graduated in foot pounds. So what you really want is ~53 inch pounds, for best accuracy you'd probably want a wrench that maxes around 100 inch pounds.
Basically, if you were setting the wrench at 6 foot pounds you were giving the bolts 30% more torque than spec.
Sounds like it's time for helicoil or time-serts.
HTH
![](https://members.rennlist.com/sharkskin/Pages_Main_1978-80-TS_Page_26-27.jpg)
#42
Dave,
It seems like it was tighter when I was taking it off than the 6 ft. lbs that I'm trying to torque it with. I'm reading about the helicoil now. Do you know where I can pick some up or is it a special order?
#43
Maybe it was but you were breaking threads loose as well as the bolt head that might have been somewhat frozen against the pump. Hardware that's been in place for any significant length of time will almost always require more torque to break free than was used to tighten them.
Helicoils are fairly easy to get. 6mmx1.0 is a very common size, any place that carries metric helicoils should have it.
#45
Under the Lift
GET LONGER BOLTS.
The holes are 17 mm deep, as I recall, but you only use maybe 5-7 mm with the standard bolts. Eh, just measure the depth with a probe and get bolts that are a 5 mm short. You'll need to tap further into the hole. Get a 6mm x 1.0 tap. WD-40 works well as tap oil. Take a little bit off the tip of the tap so you can go a bit further (there are such things as bottom taps, but you won't find one locally). You don't even need to remove the new WP to do this.
If that fails, then you can go with HeliCoil or Time-Sert. Autozone sells the HeliCoil kits. I don't know if you can install them w/o removing the pump. Fortunately I have managed to avoid using them on any 928 WPs.
