Tail light tinting...
I did a search and couldn't find the thread where someone tinted their tail lights black and someone else bought a certain paint from a hobby shop and painted them red, which is what I would like to do.
Can someone either link me to the thread or tell me what type of paint I should purchase?
Ross,
You want to use Testor's model paint, in a translucent color, in enamel, not lacquer. Some have used Hot Rod Red, and some have used Candy Apple Red to try to match the red on the S4+ brake lights for the yellow turn lights. I used a blend of these two (a light coat of one, followed by a light coat of the other for a total of about 7-8 coats. Matched up quite well.
I currently have their translucent black enamel on order to use on the side markers (I have black cars).
Gary Knox
West Chester, PA
Gary Knox
West Chester, PA
Cottage Industry Sponsor
Have you decided on all red versus red with smoked top?
Tony has them in all red, while Tom M and blown beast have them in all black.
(I need to take a new picture with my new license plate frame that reads "I BRAKE FOR CROWN-VICS")
Last weekend, I decided to use the Testors Candy Apple Red translucent to paint the orange portion of my S4 taillights. The short of the story is that after painting one of them, I was disappointed by the way it dimmed the lighting compared to the unmolested assembly. It wasn't fully dried, so I was able to remove the paint with mineral spirit, polish with 3M plastic polish, and bring it back to its original luster. I guess I'm just not willing to sacrifice luminosity for style. Once I decide to tackle the full LED switchover, I will probably revist the tinting at that time. Just my $9.28.
I had to shave off all of the embossed numbers, and sand the amber/clear areas to make them as smooth as possible. then I cleaned everything nicely and applied the tinting film. Next I used masking tape to define the edge of where I needed to trim the film (where it would meet the red section of the lens). I made lots of cuts into the film where it would wrap around the edges, and carefullly wrapped it. It takes a lot of patience to do this right, but so far so good.
I did not want to make it permanent, in case I get pulled over and don't have a set of spare lenses in my garage that I can swap-in for the inspection...
I've also used window tint on exterior car lights with good results. Another way to put the film on is to have several really sharp razor blades on hand and carefully cut around the lense where the tint meets the edge of the lense. The tint cuts easily and if you're good you will not be able to see the edge.
Plastic polish can be used to maintain the finish.
I actulaly purchased some motorcycle headlight mesh and installed it. Very simple and it's held up well, so...
Here's the link: https://rennlist.com/forums/928-forum/379871-tailight-experiment.html
Good Luck
Rod
Good Luck
Rod
