928 Forum 1978-1995
Sponsored by: 928 Specialists
Removing brake rotors
Old 10-19-2006, 02:04 PM
AO
Supercharged
AO's Avatar
Rather than paint, a thin coat of anti-sieze on the hub/inside the rotor hat should keep them from sticking in the future.
Old 10-19-2006, 02:11 PM
SharkSkin
SharkSkin's Avatar
The hub/rotor interface should be metal to metal. A better solution would be to wipe a thin film of anti-seize on the hub face.
Old 10-19-2006, 02:16 PM
AO
Supercharged
AO's Avatar
Didn't someone just say that?
Old 10-19-2006, 02:20 PM
perrys4
The Lady's Man
perrys4's Avatar
Another good reason to buy a California car. Mine cam right off.....but now when it came to the wp bolts, thats another story.
Old 10-19-2006, 02:28 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
i'll trade a stuck rotor over broken WP bolt anyday!
Old 10-19-2006, 02:42 PM
SharkSkin
SharkSkin's Avatar
DOH! I tend to load a bunch of pages at once in FireFox tabs... I missed your reply because the revlimter distracted me between loading the page and replying.
Old 10-19-2006, 02:50 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,204 Likes on 1,243 Posts
Blow Torch? Wouldn't the rotor head up and expand at a greater rate then the hub?
Old 10-19-2006, 02:57 PM
AO
Supercharged
AO's Avatar
Yes it would. And I think that's what you're after. Since the two surfaces would expand at different rates, it may break the surface corrsion that's holding it together.
Old 10-19-2006, 03:03 PM
JHowell37
JHowell37's Avatar
I just had to deal with this problem a few days ago on my '85. I tried using the method of putting a bolt in the hole and trying to push it off that way. Then the rotor cracked around the hole. So I sprayed some PB Blast in it and beat the hell out of it with a ball peen hammer. It's usually not until you start to get angry that the thing starts to move. Aluminum hubs are cool I suppose, but galvanic corrosion sucks.
Old 10-19-2006, 06:37 PM
FlyingDog
FlyingDog's Avatar
The BFH did it. I'm going to leave work in a few minutes and try the rears. Hopefully they come of easily like mentioned above.
I could find my impact screwdriver when I went to take of the rotors. One screw was already screwed up, and that one ended up being drilled. The others just needed some love taps with a hammer on the back of the screwdriver and a big crescent wrench to turn the screwdriver. After the initial pop, they spun right out.
So is the current preference for antiseize instead of paint inside the hat? That was what I had planned until I saw one of Andrew's posts on another brake job thread.
Old 10-19-2006, 06:54 PM
blown 87
Rest in Peace
blown 87's Avatar
Dissimilar metal corrosion will lock them up tight. But with heat, the different metals can help you, just watch how hot you get the aluminum hub.
Old 10-19-2006, 08:16 PM
FlyingDog
FlyingDog's Avatar
Rears came off by hand.
Old 10-20-2006, 12:06 AM
mark kibort
mark kibort's Avatar
smack it harder. it seems like its going to hurt something, but it wont. spread the banging out around the diameter it will come off! trust me, ive seen worse i bet!
MK
Old 10-20-2006, 01:07 AM
jon928se
jon928se's Avatar
Hacksaw (rotors are ludicrously soft) or grind a 1/2" deep cut in the outside edge of the rotor. Insert sharp cold chisel, smack once with BFH - Rotor should crack right through to the centre. If it doesn't come off then repeat 180degrees around.
Old 10-20-2006, 09:51 AM
Ed Hughes
Ed Hughes's Avatar
This is another example of why a torch is a necessary tool in the garage. I don't know how many times I've used mine to free up stuck parts, bolts and nuts.
Quick Reply: Removing brake rotors
