Vacuum actuator replacement
So I decided to take the console out all the way and bite the bullet - replace the center vent and footwell vent actuators. I searched rennlist and read Ed Scherer's clever procedure for the airbag cars that saved me from having to removed my dash...
So, I got the parts and decided to to the footwell actuator first. Since it's sitting outside I thought I'd just replace the whole unit. But in typical 928 fashion that wasn't possible without further major disassembly (the bracket appears to be screwed on from inside the heater box). So I opened up the existing actuator and replaced the rubber diaphragm with its little arm.
Similar approach for the center vent comb flap. But first I had to drill a hole in the heater box <crinch>. Once that was done and the pain of destroying a perfect heater box eased, it was real easy to replace. I used a 1" plastic piece from the hardware store to close up the hole. They had no matching rubber piece, which I would have preferred.
I buttoned things up and did my vacuum testing before starting the reassembly of the center console - which took forever due to a parallel interior remodeling project. Nice thing is that I was able to realign the console better with the dash than before. Now everything is straight as can be, and my footwell flap is no longer flip-flopping around...
Most puzzling to me, however, are the old diaphragms - they are nice and soft, without any visible cracking. I can't see where these would leak. Only thing I can imagine is that in one actuator, there was a hint of debris - maybe that didn't allow it to create a proper sealing surface. Really strange... I'll keep these for reference. The new diaphragms were brick red, BTW.
I have the replacements for the large fresh air actuator.
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
Turns out the center vent servo has a tear. I'm going to take one more run at removing the plastic air duct between dash and air back, but expecting to do the hole-drill-and-plug procedure.
Question for Nicole: I'm assuming you got a new pod and just swapped out the guts, or did you get one of those AutoluxMBZ parts to work?
The others are progressing well with tooling already ordered.
I have had each diaphragm drawn up and tooling designed. I am paying 100% for the full ownership of the tooling. The next step is to review samples in different materials as the technology has moved on significantly. We should be able to use a material with wear characteristics that outlive us.
As soon as I know you will.
PM me if anyone needs the fresh air diaphragm.
I have a surgical clamp, that that won't work - hole is too small. I'm going to try a long flat blade screwdriver (with small shaft) to try to weasel it onto the connector. It will be a surprise if it works, and I expect to do the hole-saw dance - but certainly worth a try. Will post results back on this thread after I get the actuator.
So you like taking the dash off? I would have replaced as much as reasonable/necessary to prevent a second entry.
