Recent list of no longer available 928 parts
Below is a repost of 928 parts no longer available (NLA). Thanks to 928 International. If there are other parts or alternatives, feel free to list them.
H2
Here is a list of numbers we show as NLA.
113 927 249
477 863 747
900 114 021 01
901 628 745 20
911 606 108 00
922 424 191 00
928 105 125 03
928 105 552 02
928 105 570 00
928 106 023 18
928 106 277 01
928 107 717 03
928 107 722 01
928 110 142 00
928 110 271 00
928 110 272 11
928 110 272 12
928 110 272 21
928 113 149 00
928 201 313 02
928 302 026 08
928 333 754 31
928 347 085 00
928 347 449 02
928 347 999 99
928 351 081 00
928 356 019 00
928 356 021 01
928 356 079 00
928 356 081 00
928 361 032 11
928 423 185 01
928 424 105 06
928 504 029 02
928 505 005 03
928 505 123 21
928 511 577 02
928 512 277 00
928 521 351 03
928 521 351 04
928 537 403 02
928 537 903 03
928 537 910 02
928 541 014 03
928 543 037 03
928 543 418 02
928 543 439 04
928 543 440 04
928 551 200 00
928 552 047 04
928 552 047 05
928 552 047 08
928 552 283 02
928 555 031 02
928 555 631 02
928 555 777 03
928 573 013 02
928 573 061 05
928 573 077 02
928 602 904 02
928 602 913 00
928 602 933 00
928 606 102 02
928 606 131 00
928 607 115 00
928 609 105 02
928 612 002 00
928 612 002 01
928 612 009 00
928 612 405 00
928 615 111 00
928 615 123 00
928 615 127 00
928 618 109 00
928 632 105 00
928 641 609 05
928 641 609 09
928 641 701 03
928 641 919 00
928 641 923 00
928 641 929 00
928 641 953 00
928 641 973 01
928 645 030 00
928 645 211 00
928 645 212 00
928 645 215 00
928 645 216 00
928 645 402 00
928 645 426 00
999 058 001 00
999 137 001 40
999 239 012 40
999 591 487 02
999 689 001 00
999 703 305 00
999 921 004 02
PNA 000 125
PNA 000 147 A
PNA 113 104 96
Mark Anderson
928 International
H2
113 927 249
477 863 747
900 114 021 01
901 628 745 20
911 606 108 00
922 424 191 00
928 105 125 03
928 105 552 02
928 105 570 00
928 106 023 18
928 106 277 01
928 107 717 03
928 107 722 01
928 110 142 00
928 110 271 00
928 110 272 11
928 110 272 12
928 110 272 21
928 113 149 00
928 201 313 02
928 302 026 08
928 333 754 31
928 347 085 00
928 347 449 02
928 347 999 99
928 351 081 00
928 356 019 00
928 356 021 01
928 356 079 00
928 356 081 00
928 361 032 11
928 423 185 01
928 424 105 06
928 504 029 02
928 505 005 03
928 505 123 21
928 511 577 02
928 512 277 00
928 521 351 03
928 521 351 04
928 537 403 02
928 537 903 03
928 537 910 02
928 541 014 03
928 543 037 03
928 543 418 02
928 543 439 04
928 543 440 04
928 551 200 00
928 552 047 04
928 552 047 05
928 552 047 08
928 552 283 02
928 555 031 02
928 555 631 02
928 555 777 03
928 573 013 02
928 573 061 05
928 573 077 02
928 602 904 02
928 602 913 00
928 602 933 00
928 606 102 02
928 606 131 00
928 607 115 00
928 609 105 02
928 612 002 00
928 612 002 01
928 612 009 00
928 612 405 00
928 615 111 00
928 615 123 00
928 615 127 00
928 618 109 00
928 632 105 00
928 641 609 05
928 641 609 09
928 641 701 03
928 641 919 00
928 641 923 00
928 641 929 00
928 641 953 00
928 641 973 01
928 645 030 00
928 645 211 00
928 645 212 00
928 645 215 00
928 645 216 00
928 645 402 00
928 645 426 00
999 058 001 00
999 137 001 40
999 239 012 40
999 591 487 02
999 689 001 00
999 703 305 00
999 921 004 02
PNA 000 125
PNA 000 147 A
PNA 113 104 96
Mark Anderson
928 International
Inventor
PET is soooo descriptive.
113 927 249 -- protection cap
477 863 747 xx clip (xx = color)
900 114 021 01 shake-proof washer
901 628 745 20 t-socket
911 606 108 00 timing mark sender
922 424 191 00 bracket
928 105 125 03 gear
928 105 552 02 roller
928 105 570 00 screw
928 106 023 18 radiator - use replacement 928 106 023 18
928 106 277 01 hose
928 107 717 03 oil strainer
928 105 125 03 gear
928 106 277 01 hose
If you remove the spaces from the part numbers you can use the "ATP" in PET to find where it's used, and you can (usually) click through to where the part itself is highlighted in the list -- click on it and it will highlight the part in the drawing. Anyone with a little time on their hands could do this.
113 927 249 – protective cap, spade terminals, horn – 78-91
477 863 747 – retaining clip, rear fender liner, 92-95
900 114 021 01 – shake-proof washer, 70-76 914
901 628 745 20 – vacuum t, central locking and washer system, 78-86
911 606 108 00 – timing mark sender, 83-91
922 424 191 00 – shift plate bracket, 78-86
928 105 125 03 – crank pulley gear, 78-82
928 105 552 02 – tensioner boot (listed as “roller”), 78-82
928 105 570 00 – tensioner arm shoulder bolt, 78-82
928 106 023 18 – “part number cannot be determined”
928 106 277 01 – radiator vent hose, 83-86
928 107 717 03 – oil strainer, 78-86
928 107 722 01 – “part number cannot be determined”
928 110 142 00 – airbox bolt, 78-852
928 110 271 00 – “horseshoe” fuel hose, 83-86
928 110 272 11 – intake tube, 83-86
928 110 272 12 – “parts number unknown”
928 110 272 21 - intake tube, 83-86
928 113 149 00 – diverter valve hose, 78-86
928 201 313 02 – fuel tank strap, 78-82
928 302 026 08 – reverse gear, 78-82
928 333 754 31 – sway bar bushing, 78-82
928 347 085 00 – three-spoke wheel horn pad, 78-82
928 347 449 02 – return line, pump to rack, 78-82
928 347 999 99 – “parts number unknown”
928 351 081 00 – front disc backing plate, 78-82
928 356 019 00 – fuel line to accumulator, 78-82
928 356 021 01 – fuel line from fuel pump, 78-82
928 356 079 00 – fuel hose from fuel filter, 78-86
928 356 081 00 – fuel return hose, 78-86
928 361 032 11 - “parts number unknown”
928 423 185 01 – clutch hard line for 9” brake booster, 78-82
928 424 105 06 – shift ****, manual, 78-82
928 504 029 02 – rear belly pan, 87-95
928 505 005 03 – bumperette, 78-86
928 505 123 21 – rear bumper cover, 87-91
928 511 577 02 – sealing plug, front weather-stripping, 78-86
928 512 277 00 – rear spoiler base, 87-91
928 521 351 03 – seat adjustment switch rose, 83-86
928 521 351 04 - seat adjustment switch rose, 83-86
928 537 403 02 – side molding clip, 78-82
928 537 903 03 – door lock cylinder, 78-82
928 537 910 02 – window regulator, 78-86
928 541 014 03 – windshield, brown tinted, 78-82
928 543 037 03 – left rear window frame, 78-82
928 543 418 02 – left rear side molding, 78-82
928 543 439 04 – connecting piece, rear side window molding, 78-91
928 543 440 04 – connecting piece, rear side window molding, 78-91
928 551 200 00 - “parts number unknown”
928 552 047 04 – center console inlay, 78-82
928 552 047 05 – center console inlay, 78-82
928 552 047 08 – center console inlay, 83-95
928 552 283 02 – shift frame, 78-82
928 555 031 02 - “parts number unknown”
928 555 631 02 – luggage net
928 555 777 03 - “parts number unknown”
928 573 013 02 – evaporator, 78-86
928 573 061 05 – a/c control head, English, 78-82
928 573 077 02 – recirculation flap vacuum valve, 78-82
928 602 904 02 – “parts number could not be determined”
928 602 913 00 – distributor dust cover, 78-86
928 602 933 00 – vacuum advance unit, 78-82
928 606 102 02 – auxiliary air valve, 83-86
928 606 131 00 – lower throttle microswitch, 78-86
928 607 115 00 – engine wiring harness, 83-86
928 609 105 02 – plug boot socket, 78-82
928 612 002 00 – engine wiring harness, 78-82
928 612 002 01 – engine wiring harness, 78-82
928 612 009 00 – battery ground cable
928 612 405 00 – rear harness, 83-91
928 615 111 00 – XVIII relay, 78-82
928 615 123 00 – seat relay, 78-82
928 615 127 00 – headlight relay, 78-82
928 618 109 00 – kick-down relay, 83-86
928 632 105 00 – engine compartment lamp socket, 78-86
928 641 609 05 – central warning light assembly, 78-82
928 641 609 09 - central warning light assembly, 78-82
928 641 701 03 – clock, 78-82
928 641 919 00 – oil/volt gauge, 78-82
928 641 923 00 – PCB for instrument cluster, 78-82
928 641 929 00 – center console light support/frame, 78-82
928 641 953 00 – temp/fuel gauge, 78-82
928 641 973 01 – PCB for instrument cluster, 78-86
928 645 030 00 – manual antenna, 78-82
928 645 211 00 – tweeter, 87-95
928 645 212 00 – mid-range speaker, 87-95
928 645 215 00 – bass speaker, 87-95
928 645 216 00 – bass speaker, 87-95
928 645 402 00 – front speaker, 78-91
928 645 426 00 – rear speaker bezel, 83-95
999 058 001 00 – screw for passenger’s side cover, 87-95
999 137 001 40 – heater hose connector, 78-82
999 239 012 40 – washer hose, 78-82
999 591 487 02 – speed nut for exhaust shield, 78-95
999 689 001 00 – rubber mount, fuel dampener, 78-86
999 703 305 00 – rubber fan mount, 78-82
999 921 004 02 – screw for front spoiler frame, 78-86
The Parts Whisperer
Speaking of NLA stuff here is a rear cat cover for 87-95 on ebay. No affiliation.
http://cgi.ebay.com/ebaymotors/PORSC...33154684QQrdZ1
There is NO way to KNOW what Porsche will decide is no longer going to be profitable to reorder. They look at sales history look at their minimum order size. Look at the new cost and then decide make it or not. Sometimes the company which made the original part goes out of business or the mold ,jig,fixture wears out .....The S front spoiler was not available for a couple years story was tha company was out of business Porsche found a new source but at a higher price. We only KNOW when a part is NLA when the well is dry...Porsche is no longer REQUIRED to make ANY 928 parts USA law is only for 10 years as I recall.
928 Engine Re-Re-Rebuild Specialist
So when a part becomes NLA, can anyone else start producing them or do they need a license to do so? (I am ignoring any cost/price considerations)
CRAP, i needed one of those CAT covers, I thought they were available i priced one a few months ago. HAd i known i would have gone higher on this one then i did.
Mark, Do you have some of these laying around that are straight?
