Top End Hesitation
Hypothetically, if an 87 S4 automatic was to start hesitating at around 100 MPH and the driver has to play with the gas pedal to get it over 100 and it continues to hesitate what would cause this? Also I beleive the car passed that mark with no hesitation a few days ago. I have no records of the fuel filter ever being changed would that cause the above problems?
Note: For anyone that has anything to say about speed limits and safety send me a PM.
Ross,
I don't know if the '87s had the in tank fuel pump, but if so that is a suspect here. You may want to pull a spark plug or two immediately after a hard run to check the color. If dark and wet looking, you should look to ignition issues. If very light or white, check fuel deliver (lean)-filter, pump (in tank/external), or filter. Fuel needs under load at 100mph are much different than at cruise around town.
There are many other possibilities, but those are easy to check .
BTW, be carefull. Things happen real fast at those speeds.
Jim
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Jim
Man of many SIGs
Lets see.
1. "Mystery" illegal substance in the glovebox
2. 10 days out of school suspension for having a knife in school
3. Extremely excessive speeds in a flashy red Porsche
The chances of you being able to go the the Daytona PCA race and Shark gathering are getting slimmer by the day.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I never said there was anything illegal in my glovebox, I just asked in the case if I ever did have something illegal in my glovebox if I could lock it and be relatively safe.
I also never exceed the speed limit and the officer planted the knife on me when she searched me.
I will be at Daytona.
Chronic Tool Dropper
Originally Posted by Darien Nunn
Clogged CATS!!
For those reading at home, this is perhaps one of the easiest things to check. A vacuum gauge attached directly to manifold vacuum will go to atmospheric pressure and the car will no longer accellerate. In Whitefox's case, that would be at 100 MPH, but it obviously changes depending on how plugged the cats really are.
Keep in mind that a really worn engine will show the same thing on the vacuum gauge, as will wrong ignition or cam timing. If it pulls hard then flattens out quickly at speed, and it isn't missing, suspect the cats.
Or a test-pipe
When I installed mine, it made a huge difference.
Captain Obvious
Super User
Super User
Originally Posted by whitefox
The only solution must be an X-pipe then huh?
