So I broke my rear shocks down tonight and I am a bit surprised how easily they compress, it only took maybe 30 - 40 lbs of pressure to compress them. I know very little about shocks/suspension so I may be missing something? My Shark only has 75K on it so I figure they should still have some life left in them but I have always felt the ride was mushy.
What's the easiest way to get the height adjuster off?
I would say as a rule, typically 60-80K miles honestly. Age maybe something to go by as well as our cars are typically going to be older then the average car with less miles then the average car of its age. I think that makes sense. I think as the car ages and shocks too for that matter the seals will dry up, you will over time leak fluid and as such loose dampening efficency as well.
I am just glad our shocks dont cost "that much" for top of the line stuff. The car I owened immediately before this one needed shocks replaced and required $700 per corner electronic dampening units. I never got around for paying for those and the ride suffered as such. I am glad i can now get 4 beautiful Bilsteins for what would have gotten me just one on my previous car.
I can only tell you what I found when I replaced my same shocks last fall at 17 years old and 140k kms.................they were done, finished, no damn good.
Your shocks are getting toward the same age and mileage.............probably time for new.
If you buy Bilsteins you don't have to worry about adjusters........they come with new ones
Compared to mine that is a lot, my fronts you just had to breath on.
Fronts come of with hammer and piece of wood, if you are real lucky the rears will come of the same way. If not you need to cut up the shock and then put a hacksaw throught and cut out the shock from the adjuster.
With low-pressure gas shocks, 30-40 lbs doesn't sound necessarily worn. It's hard to assess how they will perfom under a road load. I think the bounce test on the car is still pretty good. Comparing my bounce to other 928s was VERY revealing. Everybody else: push fa corner down hard, shock just comes up in rebound and stops. Me: shock comes back up and starts back down again = more oscillation. Open the rear hatch and shake the car hard side to side using the opening. Everyone else: one quick movement. Me: the car shook and wallowed back and forth. My shocks were bad. Off the car, it was hard to tell.
The push test is not a good indicator of gas pressurized shock absorber performance.
You should expect some pressurization loss due to age and regardless of milage. The pressurization prevents cavitation and foaming of the oils in the shock. With foaming, the shock damping performance degrades rapidly.
Interesting stuff. It probably takes more like 20 lbs to compress them but it doesn't matter, new Koni's are going in
I guess the bummer about upgrading the whole suspension at once is I won't really know which individual parts made the biggest difference.
