Mark, so you are saying then, just disconnect the couplers at the end of each hose and pull the hole spider off? Obviously the fuel system and stuff needs to come off as well no?
Anyone know if the spider intake will rust (as steel parts do) after a light wire wheel brushing?
I tried, degreaser, 50/50 water/muric acid on the left.
I then gently wire wheel brushed on the right.
Is a heat resistant clear coat necessary to avoid rust?
I'll tape up the holes before spraying but any other heads up on cleaning the spider intake manifold much appreciated
I have several. This is a 1980. But I'll look into how to add it to my signature as well. Thanks.
Can you help with the hole and any possible connector I'm missing?
For '78-79 CIS cars that hole through the manifold is to get access to the fuel mixture adjustment screw on the air elbow guide. On an L-jet '80-84 I think it's an appendix and doesn't do anything, but I've never owned an L-jet car so I'm not 100% sure.
