Turbo vs. S/C
Enjoy!
Denotation (pre-ignition) may not seem to cause any short term problems, the the millions of stress cracks kill motor life spans. How do you SC guys run a supercharger on pump gas in your 10-1 S3s and S4s?
Mark O
Mark O
Read Corky Bell's book on Turbocharging or his othe book about supercharging for the exact formulas, but my S2 with 10.4:1 compression could only do 5 psi with these calculations at best, and this low boost means too low HP for the coin....though 928 Specialists is developing a good kit for these cars, along with Mark Robinson out in Austin. Stay tuned.
Your car? www.928gt.com has your supercharger kit. I suggest you read Andrew Olson's threads to see how much fun this particular "personal roller coaster" can actually be.
N!
I don't think the S4's actually measure out at 10:1, as I recall it's more like 9.5:1.
The pentroof design is boost friendly, also.
N!
N!
From vortech's website in the FAQ section:
26. Why don't Vortech superchargers need an Aftercooler or an intercooler?
Vortech Engineering, LLC has conducted extensive testing of most intercoolers/aftercoolers currently on the market. Test results indicate that for street driven purposes below 8-9 PSIG, installing an aftercooler has marginal effects when using a Vortech supercharger (due to the high efficiency of the supercharger). Nearly all of the intercoolers/aftercoolers available on the market have poor effectiveness and actually can cause parasitic losses equal to or greater than the power gained by installing a intercooler/aftercooler. Vortech has developed systems which are substantially more effective at lowering discharge temperatures without causing driveability problems and pressure drops thru the cooling core and ducting.
The Murf928 Stage One will run between 7-8psi. It will run close to 7 psi with an intercooler and make another 35-40 rwhp. This is the max you can run with the stock injectors.
So Normy, you would recommend reletivley untested systems (no dig on DR and Mark, I know they are doing their homework) and not even mention the one that's been out there the longest and has proven to be susccessful? Wassup?
Thanks,
Klim
It would seem your results conflict with Vortechs... I wonder what kind of crap intercoolers they were testing???
So Normy, you would recommend reletivley untested systems (no dig on DR and Mark, I know they are doing their homework) and not even mention the one that's been out there the longest and has proven to be susccessful? Interesting.
adiabatic efficiency in the region of 75 - 80%. So the only reason, theoretically, us TS'ers need an intercooler is because the power comes on so early? After, say, 4500 R's our IC's aren't helping much, if any?
I have a hard time believing my intercooler causes me any parasitic loss or that cooled intake air won't evercome the parasitic loss from my puny little water pump.
As far as efficiency goes, the cs and turbo are pretty close, the TS slightly less efficient and the roots is by far the worst.
Now, I'm not saying that you should not run an intercooler. I think intercoolers are a great idea. They add a lot of complexity to the installation as well as cost so one has to weigh out the pros and cons. Most sc systems sold today by the major manufacturers do not include intercoolers. As far as what I am doing, The 89GT and GTS cars are true 10:1 CR and they will get a pulley that will run slightly less boost if they are not going with the intercooler. So far, all the kits sent out for those cars have been intercooled. I can provide a pulley for whatever someone wants to run, as long as it is less than my recommendation.
There are quite a few non-intercooled supercharger kits available for other types of cars that have 10:1 or even higher compression ratios. There's a lot more than boost level and compression ratio that determines if detonation will occur or not.
People on here have done it without problems, and are still doing it without problems. You can believe them, or you can believe those who've never even tried it and say it can't work.
