FINISHED 928 TurboSport kits! S3 & S4: Pictures!
#46
Thanks guys. It is a bit of a struggle doing this on my own & budget: esp. averaging 60hr work weeks since Jan.
I'll indeed address the automatic 928's: no worries there, just need a little time.
#56
Will fit on all exhaust manifolds: as the early are interchangeable with the '85-86. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Weight: i'd say the entire turbo system weighs about 30-40# lighter than stock. I'll do the weight comparison with the new car when it arrives. FYI: the main Y-pipe weights a mere 8.5 lbs!!
#57
since catalytic convertors will inter change the Y pipe replacement would also... The three bolt triangular flanges end up in the same place 16v or 32 valve it is the ports which move.
#58
good to know. BTW: that "ODD" pipe in my list of pictures is the Y-merge pipe that allows x-pipes to slide into a single 3" adapter, to keep them even with the turbo kit.
#59
