+Brake noise toc toc toc+
1 Post
Just had my brakes pads and rotor replaced on all 4 wheels. 928S 84
At first, everything was fine and then it started to toc toc toc when aplying the brakes...the freequency is in relation to speed. The faster the wheel turns the faster the toc toc toc. To my noledge(sp), I don't have ABS... It appears to be coming from the front driver side. the rotors are the sloted kinds. To late to take the wheel off, but I did feel the bolts and to the touch looks tight.
Anyone experienced that? What might it be???
Yes I will contact the wrench(not an amateur) as soon as possible!
thanks
thanks
Under the Lift
Perhaps something got caught in one of the rotor slots. Jack up the suspected wheel and spin it while observing. Look on the inside as well.
1 Post
Will report back....
1 Post
Just talked to the wrench and he says that the rotors and pads that I have are JUNK. http://www.vertexauto.com/index.php?...detail&sk=2109
According to him, the slots should be "beveled" and these are not and the pads were not antiratle equiped (nothing in the box).
OK, you might say he could have caled me (wich he almost did) but I have only me to blame for buying them (not knowing they were junk).
He say that if the situation does not improve by the end of the week, to drop by and he will bevell them...he won't leave me like this he said...sound like a empathic(sp) fellow.
Moral of this story, check with your local friendly neighbourhood wrench before bying stuff and here as well...
Any of you have experience with these rotors??
Dan,
Don't know if this applies to you, but I bedded in my brakes and all was good...
https://rennlist.com/forums/928-forum/279448-rythmic-grinding-noise-when-applying-brakes.html
Got my brakes from Vertex as well.
Best of luck with it.
Regards,
Bill
Regards,
Bill
928 Engine Re-Re-Rebuild Specialist
Originally Posted by Andrew Olson
Could be a loose rotor weight clip or a rock
1 Post
Originally Posted by Wild Bill
Dan,
https://rennlist.com/forums/showthread.php?t=279448
Regards,
Bill
Regards,
Bill
Don't know if it will help with the "jumping pad" syndrom but will help with braking power wich at the moment is weak to say the least...
Originally Posted by Big Dave
And the award for the largest signature on Rennlist goes to.....
He could have at least turned off spell check on his write-up.
