928 Forum 1978-1995
Sponsored by: 928 Specialists
E85?
Old 10-30-2007, 12:24 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,223 Likes on 1,253 Posts
Originally Posted by BrendanC
The solution to the ethanol and alcohol (and even methanol - but its a lot more dangerous) is to simply use SS hard line, or Nickel plate anything aluminum or brass. For soft line, Teflon line is used. At that point you have a 15-20 year fuel system at worst.
There are other types of fuel lines (non-solid) designed for ethanol. When I do the EFI conversion on the 79 I'll be replacing every rubber fuel line.
Old 10-30-2007, 03:46 PM
BC
BC's Avatar
You mean other than teflon?
Old 10-30-2007, 06:11 PM
Brett928S2
Brett928S2's Avatar
Hi
Ummm maybe I am misremembering but didnt somebody try this stuff in a 928 about 18 months ago and it "MELTED" his tank ???
Melted ...as in small hole and leaking fuel...and partially blocked fuel lines...
All the best Brett
928 S2 AUTO V8 4.7 LTR 1986 IRIS METALLIC BLUE WITH X-PIPES ,RMB ,PROMAX CHIPS,
KICKDOWN SWITCH - K&N FILTER - WIZARDS OF NOS - NITROUS KIT 150 HP - 505 HP/500 FT LBS TORQUE -
PCGB UK 928 FORUM MODERATOR - Email managingdirector@pchealthcare.co.uk
Old 10-30-2007, 07:08 PM
BC
BC's Avatar
Originally Posted by BRETT AINLEY
Hi
Thats entirely possible. Do you have the thread link handy? The plastic is 20 years old. I was kind of assuming either tank replacement or something similar.
Old 10-30-2007, 07:11 PM
hacker-pschorr
I'm not sure the material. I'll update you once I have more info on hand. This hose is designed for race cars.
Hey, Brett is alive
Old 10-31-2007, 09:34 AM
Brett928S2
Brett928S2's Avatar
Hi
The thread I was remembering was on here....I have done a search but cannot find it....unless anyone can remember it ?
All the best Brett
Quick Reply: E85?
