pocono de this weekend - no luck !
well it started great and ended bad ...
i had to leave early secondary to some clutch problems which i dont have a diadnosis at the moment but it does not look good. i have some pics of the good and the bad...maybe you guys could help..it looks like i may need a new upper bell housing...check it out !
thanks
v-tach
1986.5 ..5sp
thanks
v-tach
1986.5 ..5sp
Hi I would suspect that you have a worn trans mount or motor mount or both might not be a bad idea to replace all of the mounts and make sure to check the drive shaft for trueness before installing the new bell housing, also make sure the bolts that hold both ends of the torque tube are tight, I hope you get it fixed without too many surprises, Stan
Hi Bill your right I thought it might be the bellhousing but after looking a lil bit more it could also be the transmission , either way there is probably a soft/broken mount on either the engine or trans
and if it is the trans then there might also be a worn /soft suspension link possibly letting one of the halfshafts move to far towards the transmission, make sure to spin the driveshaft see if it got bent
i will post some more photo's. the photo's are taken from the engine compartment closer to the driver side and firewall. the clutch lever has a plastic bushing an is connected to that area of the bell housing.. sort of like a ball and socket.
thanks
v-tach
thanks
v-tach
Ahh the clutch arm pivot bolt support cracked, well you will be looking at replacing the bellhousing, there may be other worn parts on the clutch release arm maybe a worn TOB to clutch arm or the guide tube has to much play or has come loose open up the bottom clutch cover and take more pictures
the clutch assembly was just taken out and inspected -- found to be fine ! the only thing that was replaced was that little plastic bushing attached to the clutch lever..
v-t
v-t
Apparently that did not belong in there. As for how it may gotten there hopefully you know. If it was a clutch spring you wouldn't feel as bad.
It does look like you had a great time at the track though. Hope you will be back up and running soon.
