928 Forum 1978-1995
Sponsored by: 928 Specialists
which supercharger?
Old May 11, 2006 | 12:35 PM
  #31
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
Originally Posted by the flyin' scotsman
Yes, we're far away from anyone I'd trust with the car............done all the work (see mods) myself including MMs and suspension.
So then you will want a complete "kit"......
See what DR has, and when it will be ready for retail. As far as I know there are only two options available for complete, fully designed kits, and I don't think DR has his out quite yet. DR is a CLASS guy, when he does offer the kit for retail, I have every reason to believe it will be complete, bullit proof and "purdy". (unlike the previous stuff available from another source)
The Murph stuff has been available for several years and has many successful installs done by owners like myself who have some familarity with a wrench. The install manual has been edited several times and is as complete as it could possibly be, including pictures. On top of that, Murph is a CLASS guy, as is Carl (who is his retail outlet).
The Murph install was trouble free, interesting, nearly idiot proof and has been bullet proof for a couple of years now, (as JimR also attested). There are several things I really like about it. One thing is it can be very easily removed and return the car to stock.
Old May 11, 2006 | 01:10 PM
  #32
Herr-Kuhn's Avatar
Herr-Kuhn
How about we see some performance numbers for each...on a real road with real cars? Not talking 0-60 or 1/4 mile or even dyno chart here...but rather all out driving.
Don't knock mid range torque until you drive it! We need to have EC or another tuner magazine do a Boosted Shark Shootout!
Old May 11, 2006 | 01:18 PM
  #33
hacker-pschorr's Avatar
hacker-pschorr
Administrator
I think EuroSport does a tuner challange every year - any kind of car is welcome. It would be great if one of each setup entered.
Herr, I don't think anyone is knocking high mid-range boost. Us in the centrifical camp are just trying to point out low end torque is not missing from our setups.
Old May 11, 2006 | 01:27 PM
  #34
Herr-Kuhn's Avatar
Herr-Kuhn
Hacker...little Goldiewang made 355 ft-lbs on 9-10 psig. Upgraded Callaway...415 ft-lbs on 11-12 psig. Both those are tire numbers. I have yet to see a 4.5 centrifugal car make that much mid range punch...not sure on a positive as we have yet to see a 4.5 with a screw compressor.
I have a really neat article done about 4.6 liter Fords and different induction methods...will see if I can post it up here.
Old May 11, 2006 | 01:33 PM
  #35
Imo000's Avatar
Imo000
Captain Obvious
Super User
I'm a little confused. What is you definition of all out driving? Is it a road course or just on the street?
Old May 11, 2006 | 01:35 PM
  #36
BC's Avatar
BC
Originally Posted by Hacker-Pschorr
t
With regards to power down low for the Centrifugal setups, I'm not sure why 360ish rear wheel torque at 1,800rpm is considered "no low end torque" for a car that maxes out at 395 @ 4,600rpm. This is the current output of Tim's stage 2 kit. Exactly how low do you want full torque? At idle?
This has always been my point. It is my opinion that peope who speak of needing more torque down low, before 3k rpm, either have some stock in tire companies, or haven't driven a truly fast boosted car.
Old May 11, 2006 | 01:49 PM
  #37
Jim R.'s Avatar
Jim R.
Low end torque on the Murph setup is more than enough to shred a set of SO2-A 295/30/18's at will from off idle on up. When I had 255's, wheelspin through 4th was common. More than enough low end and midrange torque for me with a brutal pull to redline. Different driving styles, different methods of boost. I only drop 1500 or less RPM's between shifts, so dropping out of the powerband is not an issue.
As far as driving experience, 0-60, 1/4, and regular "spirited" street driving, it has far exceeded my expectations based on much previous experience with modified street and drag cars. We can all compare dyno charts; try going for a ride or driving one before making any one system to be better than another. Anything else is pure conjecture, nothing more.
Jim
Old May 11, 2006 | 01:53 PM
  #38
AO's Avatar
AO
Supercharged
DR's setup should be available later this month or right at SITM time - but there is a bit of an order backlog from what I understand.
Old May 11, 2006 | 01:54 PM
  #39
hacker-pschorr
Administrator
I know your cars are putting down some awesome numbers.
It will be fun to see what my 79 does with a blower since it's already at 280ish ft-lbs stock. Adding 100 ft-lbs should not be very difficult.
We should have number from a boosted 4.7 Euro very soon.
Old May 11, 2006 | 02:35 PM
  #40
all4woody's Avatar
all4woody
"However the highest dyno tested S/C 928 ever was a Murphy kit...up to 556whp vs 470whp for the Twin Screw?"
IcemanG17,
Do you know what the psi was on the Murph kit to make that kind of HP? Just wondering if I can do that with 10:1 compression. Thanks, Woody
Old May 11, 2006 | 02:39 PM
  #41
TAREK's Avatar
TAREK
IcemanG17,
I think Tim Murphy would tell you that his CR was certainly not stock...modified to mid 8's IIRC
Old May 11, 2006 | 02:53 PM
  #42
Lizard928's Avatar
Lizard928
what I dont get is why all the scare of boosting a high CR car, the 928 has a good combustion chamber to start with, and alot of the german cars made today are being run with 9.3.9.5CR stock, and some as high as 23PSI of boost.
I know of a few cobra mustangs with the 4.6L engine in them pushing 21PSI with a roots style and having no issues on FACTORY EFI,
if you were to convert to standalone and have proper spark retard, and a efficent IC, I see no reason that you could not run 1 bar of boost on bone stock internals, sure if you were to drive it really hard with that (ie drag stip all the time) then you may yes run into some engine trouble, but if you only use that power out on the freeway and drive it half sane, I dont think you would see any real issues.
and 1 bar of boost from twin turbos on 10:1 CR and standalone with an efficent IC should yeild over 600BHP with ease.
I do have a spare engine that I have incase I do destroy the one that is in there, but I for one what to what it is able to do, I will probably run like that for a few months then tear down and see wear. but it will be alittle while before I am able to get this fully setup.
Old May 11, 2006 | 03:22 PM
  #43
Larry928GTS's Avatar
Larry928GTS
Registered User
So you're suggesting that we leave out the forms of performance measurement that would most minimize the possible variables, and instead use one that introduces the greatest number of possible variables, the biggest being the driver. Sounds like a good plan.
Old May 11, 2006 | 03:29 PM
  #44
BC's Avatar
BC
I fully agree. I have my 89 engine ready for just this. The pistons have been coated for temp on the crown and side skirts, and I have installed ARP rod bolts, and will use ARP head studs, and an MLS gasket, with standalone EFI. It should hold together when I get the tune right. Just need sometime for assembly.
Old May 11, 2006 | 03:39 PM
  #45
hacker-pschorr
Administrator
what I dont get is why all the scare of boosting a high CR car...............I know of a few cobra mustangs with the 4.6L engine in them pushing 21PSI with a roots style and having no issues on FACTORY EFI
These other cars do not have a raised cylinder deck, alusil block. It has been known for some time by the 951 crowd, too much boost will damage the thin cylinder walls. The 928 has even thinner walls than the 944 turbo. Reason why Todd came up with the cylinder support ring the higher boosted S4's are using. Not to mention there is not a reliable way to reduce ignition timing on these cars (yes I know something is in the works, I am not aware of a successful test yet).
Too much ignition timing + high compression + thin alusil cylinder walls = game over man
