928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil leak. (updated: camseal, maybe broken camshaft?)
Old 04-13-2006, 03:18 AM
SharkSkin
SharkSkin's Avatar
Seals sometimes just wake up one day and say, "This is a good day to die".
As for the power loss, could be a number of factors. Maybe the oil is buggering up your plug wires. Maybe with all that oil, a marginally-tight TB could have skipped a tooth or two. Also, if pressure to the lifters is reduced, you might not be getting full valve lift on that bank, though AFAIK even bottomed lifters will only affect lift by maybe 10-20% tops.
Old 04-13-2006, 01:05 PM
k1woods
k1woods's Avatar
I've had a right cam (Passenger side) break. Symptoms include a loss of oil, very rough running engine, wobbly cam gear.
- Kevin 84 S2
Old 04-13-2006, 01:46 PM
ViribusUnits
ViribusUnits's Avatar
Another weird thing is that the engine doesn't really seem to run rough. Just get to about 4 grand, and there is absoutely no power.
How do I check which seal it really is? Maybe stick a drill on the oil pump, and see where it leaks from?
Old 04-14-2006, 03:27 AM
SharkSkin
SharkSkin's Avatar
You'd have to pull the TB to do that. Simple Green, a brush, and a hose. They're your friends.
Old 04-14-2006, 03:35 AM
karl ruiter
karl ruiter's Avatar
If it does turn out to be a passenger cam after all, let me know as I am pretty sure I have and extra one floating around (If I have not already tossed it). When I replaced my drivers side I had to buy a pair.
Quick Reply: Oil leak. (updated: camseal, maybe broken camshaft?)
