"Tip in" tuning, as Ernest says
#46
Originally Posted by Jim_H
It's not tip in.
Maybe vacuum related?
I'm sure one of the pros will give you some things to chase down.
do i need a vacum reservior?
#47
Under the Lift
The flappy vacuum source is the 4-way up near the brake booster. The vacuum reservoir is for the cruise control and is another arm off the 4-way that goes towards the fender. So, you need to check that that is holding vacuum. If your cruise works, then it is OK.
Have you checked the blue/black check valve that is near the 4-way? Here's picture of my 4-way.
#48
yes cruise works that rules out res. I am thinking must be a/c related so the easy check would be to block off the a/c line and see if she will work then..correct?
#49
Under the Lift
Each line off the 4-way should hold vacuum. So, sure, pull the AC and test with a MitiVac. Test all of the lines. Test the check valve to. It should be easy to blow one way, but not the other.
