928 Forum 1978-1995
Sponsored by: 928 Specialists
"Tip in" tuning, as Ernest says
Old 04-05-2006, 07:25 PM
  #31
Garth S
Garth S's Avatar
Originally Posted by John Speake
It sounds as though the performance chip has dialled in too much fuel at that combination of rpm and load. ...
... As Jim said as well ( post #25): agreed that a rich condition could also cause the symptoms described; however, I stupidly believed the data in post #3 - which clearly indicated a lean condition ... Only believe X% of what you read ...
Old 04-05-2006, 07:36 PM
  #32
Bill Ball
Under the Lift
Bill Ball's Avatar
He says things are worse w/o the aftermarket chip. So, it's relatively dead off the line. Cam timing. Dunno.
Old 04-05-2006, 08:02 PM
  #33
Loaded
Loaded's Avatar
When i drove the car the first time my forst inclination was EXACTLY this! Cam timing. then i thought maybe it was ignition timing etc. etc. the timing chain ws just done less the 2k miles ago.
My second inclination was injectors etc.
But honestly i wont ever know until make small adustments. I am getting an X pipe and that will do one of two things
the x pipe will clean up a rich condition
or
it will make it worse.......
How else can i get this info on the mixture ratio on the fly?
Old 04-05-2006, 08:33 PM
  #34
Bill Ball
Under the Lift
Bill Ball's Avatar
Timing BELT, not chain. In general, this has no effect on cam timing, UNLESS they put the new belt on the cam gears off a tooth or two OR they replaced the cam gears and were not careful about getting them back into the same position.
The ignition timing is fixed and set by the EZK brain. No adjustment. But if the cams are off, the timing is off relative to TDC, as you see the distributors run off the cams.
To get mixture information you can install a AFR meter.
Old 04-06-2006, 11:43 AM
  #35
Loaded
Loaded's Avatar
Another clue maybe, Havent driven rebecca in three days, Last night I fired her up and she immediately went to 11-1200 RPM and would not drop until about 3-4 minutes after that when i pulled in to a parking lot waiting for a friend it was surging RPM was bouncing from 500-750 aprox... it never stalled at all but it always surged.............
Old 04-06-2006, 12:19 PM
  #36
John Speake
John Speake's Avatar
For the first couple of minutes after a cold start the car is running open loop. So at that point you are very reliiant on the MAF calibration.
The idle is jumping around because the idle loop isn't able to allow the correct amount of bypassed air into the engine to keep the rpm down (or up) enough to get balance in the loop to keep the idle at 675rpm.
When the car gets onto the O2 loop, problems with MAF errors, and small inlet leaks are somewhat compensated for.
Check carefully there anen't any inlet leaks, check inlet vacuum. Try a MAF swap for a known good unit.
Old 04-06-2006, 09:17 PM
  #37
Daniel Dudley
Daniel Dudley's Avatar
Oil from a K&N filter has been known to contaminate the hot wire on the MAF. They also wear out over running time, particularly when the car is started a lot. I had my car to several mechanics who could find nothing wrong, but the dyno doen't lie.
Old 04-06-2006, 11:46 PM
  #38
Loaded
Loaded's Avatar
This is funny of sort I went ROG100 house and the first thing he did was rip out the KN filter the PO installed......
Old 04-07-2006, 12:34 AM
  #39
ErnestSw
ErnestSw's Avatar
I have a spare MAF you can try.
Old 04-07-2006, 12:36 AM
  #40
Loaded
Loaded's Avatar
doesnt that require manifold removal?
Old 04-07-2006, 12:51 AM
  #41
ErnestSw
ErnestSw's Avatar
Nope, the MAF sits under the air box at the back of the engine right below the air filter.
Old 04-07-2006, 12:53 AM
  #42
Loaded
Loaded's Avatar
phew! ok You know I would like you to drive it if yo dont mind? It is an AUTO and you may get used to the comfort of an auto tranny LOL
Old 04-07-2006, 01:40 AM
  #43
ErnestSw
ErnestSw's Avatar
Any time.
Old 04-07-2006, 05:46 AM
  #44
John Speake
Band new K&N are usually OK. The problems come when people clean and re-oil them. Then they often get overoiled, and that messes up the MAF.
Old 04-07-2006, 08:54 AM
  #45
SwayBar
SwayBar's Avatar
As someone else stated, it sounds like the car is starting off in 2nd gear, which is 'normal' for the 928 autos. I would make absolutely certain which gear the car is really in when conducting the tests.
Quick Reply: "Tip in" tuning, as Ernest says
