928 Forum 1978-1995
Sponsored by: 928 Specialists
Brake Caliper Pistons HELP!!!
Old Apr 4, 2006 | 02:31 PM
  #46
Bill Ball's Avatar
Bill Ball
Under the Lift
Andrew: It's Jim Morehouse's CD compilation, not me, that is a wealth of information. Everyone should review them from beginning to end. I have, but much of it doesn't stick until something like Darien's issue comes up. Your summary is correct, except I am not sure of the cost for a complete 88 rebuild kit with 4 pistons.
Old Apr 4, 2006 | 02:36 PM
  #47
AO's Avatar
AO
Supercharged
Understood on the prices. When I'm bored I also pour though Jim's CDs. My only issue is that NONE of it sticks until I actually have to BTDT.
Old Apr 4, 2006 | 10:38 PM
  #48
fraggle's Avatar
fraggle
Other threads have indicated the "early 87" is no longer available. I believe that the one with "normal" pistons, without the reliefs. I have those on mine. I'll have to either check these website or pray a bit... I tore into my right front caliper last night and cleaned everything with a couple cans of brakleen and am going to put it back on in a few minutes. Hope it doesn't leak! It all went back together nicely, I was able to work the pistons back in with brake fluid as a lubricant. It wasn't easy but it does appear to be in once piece.
Old Apr 4, 2006 | 10:41 PM
  #49
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Good luck fraggle.
Old Apr 4, 2006 | 11:24 PM
  #50
Bill Ball's Avatar
Bill Ball
Under the Lift
The changeover was in 89, as I mention above. Good thing is the SEALS did NOT change, just the dust scaper was changed to a bigger dust boot, and the piston was altered to accomodate the boot. So, if it leaks, the seals are available.
Old Apr 9, 2006 | 01:14 AM
  #51
fraggle's Avatar
fraggle
All back together and no leaks. I really wonder if this system was EVER flushed! Now it is full of ATE Blue! Pedal feel is fantastic.
