Engine Mount Torque Specs
Anyone know the torque specfication for engine mount bolts for the OB style cross member?
'79 928...
'79 928...
I think on bolts like this I would just tighten them till they tighten...
They are big, and steel to steel so, the only thing you should worry about is them unbolting. By tightening them hard there should be no worrys. That's what I did
Klim
Klim
I think that falls in the "All other nuts and bolts" category:
M6: 6-7 ft-lbs
M8: 15-16 ft-lbs
M10: 30-34 ft-lbs
If you're worried about them coming off, replace any lockwashers that may be on there, and maybe add some Loctite blue.
M6: 6-7 ft-lbs
M8: 15-16 ft-lbs
M10: 30-34 ft-lbs
M6: 6-7 ft-lbs
M8: 15-16 ft-lbs
M10: 30-34 ft-lbs
M6: 6-7 ft-lbs
M8: 15-16 ft-lbs
M10: 30-34 ft-lbs
I am sure about the sizes though...correct me if I am wrong.
Klim
Under the Lift
In general, bolt torques
17mm head (M10) = 42 ft lbs
19 mm head (M12) = 62 ft lbs
There's a range, but these are good.
M8 is 13mm bolt head
As I recall, those torques applied to all the crossmember bolts when I did the MM.
