X-pipe = no no
I received a certified letter today from Mr. Monty Campbell. Monty owns the trademark "X-Pipe" and just about all other terms with "X" in them. He requested that I not use "X-Pipe" or any confusingly similar mark in any publication or editorial content. Therefore, I have removed all reference to X Pipe from my web site. I replaced the "X Pipe" term with "V^2", or V squared. I had always thought that X pipe was a generic description of how two pipes were joined. Apparently, not so. He even has a patent on it and seems quite proud of discovering something that has been around for quite a number of years. www.x-pipe.com
So, no more references to X pipes here. I suppose the RennPolice will uphold that suggestion so we'll have no future problems with Mr. Campbell.
It's fine with me if you want to refer to X pipes as V^2 pipes though.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Do you suppose there is a trademark or patent on "H pipe", or "Straight pipe", "Headers"? How about trademarking "Wheel" denoting something that's round? Wonder if you could get a patent on air?
![order](https://rennlist.com/forums/graemlins/order.gif)
Why not "Ott-pipes"
That is also the ****tiest website I have seen in a while. He probably still types emails in Caps. Calls the computer the "CPU"
Check out what he has to say regarding the Corvette system:
"The real X-PipeTM designed and developed by the real inventor of the X-PipeTM; Monty Campbell "
"Converts excess sound pressure (noise) into increased cylinder pressure (adding 18+ RWBHP)"
"Generates 3 power peaks; at 2,000, 4,000, & 6,000 rpm!"
"Exciting, 4 channel Surround Sound experience "
But the best quote is near the bottom:
"No copy cats, please."
Hey, he did say please.....
What a bunch of crap.
Rich
Rich
1 Post
Hi ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
If you look at his copyright stuff on first page...he only has..... X-Pipe (SINGULAR) copyrighted ...NOT ...X-Pipes (PLURAL)
So just call them X-Pipes and all fine![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
All the best Brett![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
928 S2 AUTO V8 4.7 LTR 1986 IRIS METALLIC BLUE WITH X-PIPES ,RMB ,PROMAX CHIPS, KICKDOWN SWITCH.K&N.
PCGB UK 928 FORUM MODERATOR
All the best Brett
Originally Posted by mspiegle
>< pipes
][ pipes
}{ pipes
)( pipes
There, problem solved =)
][ pipes
}{ pipes
)( pipes
He does post a picture of the motor cycle pipe and is just a simple >< no partiular unique design and a terrible web site basically puts down every other high performance modification.....
I think you should call 'em "Monty Campbell" pipes, patent them, then tell him to take all references to "Monty Campbell" of his website or you'll sue his ***.
What a pin-head.
I like "Ott-pipes", has nice ring to it.
What a pin-head.
