928 Forum 1978-1995
Sponsored by: 928 Specialists
Warning to all 928 owners! - Check your headlight clips, upgrade solution post #119
Old 03-26-2006, 08:55 PM
  #46
dcmelik
dcmelik's Avatar
Thanks everybody for this thread. I checked and, as of right now, I have the C clips. Odd how the failure of a two cent part will cause catastrophic damage to the cooling system.
David Cmelik
87 928 S4 auto "guards red"
01 986 5 speed "seal grey metallic"
00 BMW 323i black on red
Old 03-28-2006, 10:48 PM
  #47
JG928S4
JG928S4's Avatar
Reading this reminded me to check again, (did 3 months ago), and today the botom clip is missing, better try the size from Ace as described, and be diligent to check on a regular basis.
Thanks,,,,,,,
Old 12-26-2006, 11:04 AM
  #48
RngTrtl
RngTrtl's Avatar
With a bunch of new 928 owners out there over the past year I thought I would bump this one up for all the newbies to see.
Old 12-26-2006, 11:48 AM
  #49
F4GIB
F4GIB's Avatar
Originally Posted by JPTL
I've found a better E Ring as a replacement at the local Ace Hardware.
The replacement ring is an s.a.e. 1/4" ring, so it fits on the collar a bit more snugly. I've also compared the o.e.m. washer to a nearly identical 5/16" grade 8 hardened s.a.e. washer at Ace that is a near perfect replacement.
I'm guessing that most Ace's nut & bolt vendor is the same. Anyway, this vendor is Hillman in Ohio. The stock numbers for these are as follows:
E Ring: 873-L
Washer: 2817-B
Ace is the place. I replaced both of mine and carry 4 spares. I check every time the hood is opened.
Old 12-26-2006, 04:27 PM
  #50
alex70
alex70's Avatar
Thx Rng, this is sure worth the bump, didn't see the original post and will check the clips on my way out today....
Old 12-26-2006, 04:38 PM
  #51
Rufus Sanders
Rufus Sanders's Avatar
Wow. I knew the c-clip issue existed, and have checked mine often, but I did not knw the motor would auto-cycle. I guess they really mean it when they say "Step 1. Disconnect the battery"...- Ruf
Old 12-26-2006, 04:43 PM
  #52
danglerb
danglerb's Avatar
Doesn't anybody have something more reliable than a C clip yet?
That whole post should be replaced with something harmless.
Old 12-26-2006, 04:50 PM
  #53
Andre Hedrick
Rest in Peace
Andre Hedrick's Avatar
The is a star clip for one time usage. You have to break it to remove it, and they are usually stainless. I would worry about ion interaction when mixing metals. A snap ring might work too, has anyone tried them or E clips?
Cheers,
Old 12-26-2006, 05:37 PM
  #54
borland
borland's Avatar
I found this removable locking clip in the PET that is the correct size and will work great. So no more worries or unnecessary looking under the hood.
You need two, and can order them from Porsche or any of the Big-3. Use this part number and nomenclature:
999.166.005.02 sl-lock
This part is used on the S4 automatic shifter mechanism (PET shifter mechanism, item 9). If you want to see another SL-LOCK, without disassembling the console, but of a larger size, the throttle pedal mechanism also uses one.
borland
90’ S4, Slate Metallic
Old 12-26-2006, 06:44 PM
  #55
Tony
Tony's Avatar
This is one the many items that Wally mentions! Ive got it on my webiste somewhere as well. Years ago when he told me about it...sure enough..disaster waiting to happen!
Check them!
Second pic down #21
http://members.rennlist.com/v1uhoh/underthe.htm
Old 12-26-2006, 09:11 PM
  #56
auzivision
auzivision's Avatar
I checked mine... not a problem, but I appreciate the heads up… such an easy check.
Now if I can only get around to unboxing Porken’s lifts bars and using a recently acquired micrometer... perhaps the TBF will be adverted.
I’ve added the Halon fire extinguisher and plan on replacing the fuel lines soon. I don’t have a spare LH or MAF and hope they are good for a few more clicks.
It’s always something to watch out for… What would we do without this site?
Old 12-26-2006, 09:36 PM
  #57
F4GIB
F4GIB's Avatar
Picture, please
Old 12-26-2006, 09:54 PM
  #58
ceedee
ceedee's Avatar
Originally Posted by bfellows
Ditto Larry!
triple that...
and bump
Old 12-26-2006, 09:58 PM
  #59
borland
borland's Avatar
Here's the SL-LOCK clip.
http://img228.imageshack.us/img228/2...ockclipbs9.jpg
You still need the backup washer, but this installs in place of the C-clip. The lock feature keeps it in place.
Old 12-27-2006, 01:55 AM
  #60
alex70
alex70's Avatar
Good golly! Lower one is missing on mine!
Thx again Rng!
Quick Reply: Warning to all 928 owners! - Check your headlight clips, upgrade solution post #119
