Replacing ignition wires on an S4 (How not to)
That's right. Read it and weap. 4 hours and just putting stuff back together. 944's, VW's, Fords, Volvos, nothing compares to the mess of getting these things replaced as a first timer.
The old, cracked, brittle and shattering covering from the BERU wires went everywhere but in the belt covers. Lost a washer from the guide plate that runs across the front of the engine that I need to find and I think that I may have two wires reversed.
I'll post pics when I get it wrapped, clipped up.
Michael
Michael
89' and later coil wires are different than earlier coils. We have sets of both in Magnecore 8.5mm available cheap if you need to convert. If you use S4 wires on an 85'/86', they will be a bit long but that's much better than being short...with factory routing the 85/6' wires will be short on an 89'.
Under the Lift
Ross, you are wise beyond your years. Most people probably do that. I actually tried to make them go exactly as original, finnagling them under the coolant inlet and other obtructions.
Yippie, that was a total of 6 hours for the newbie! Steve, thanks for the offers to help.
Turns out I got all the wires right after looking at the WMS. I even got them back in the "original" places. Only thing that changed was that I removed the Beru wire fasteners from the head. No they are not for sale
Michael
Michael
Under the Lift
Originally Posted by whitefox
Well I figured I would want to save time if I ever had to re-tension my power steering belt.
Just about to do this..so can I remove the lift hook on the front of the engine without problems? Can't see how to reach the nuts on the back of the hook otherwise..
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
It only took me an hour to do mine.. even including installing the old connectors on the new economy kit wires...
I thought it was easier than an oil change...
