928 Forum 1978-1995
Sponsored by: 928 Specialists
Water Pump Bolt Position
Old Mar 5, 2006 | 02:45 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Good job, Doc.
Old Mar 5, 2006 | 03:48 AM
mark kibort's Avatar
mark kibort
you can see the open hole to the right for the timing belt cover.
mk
File Type: jpg
Old Mar 5, 2006 | 03:54 AM
mark kibort
actually, Bill has the correct hole for the timing belt cover. I show it on my picture of the pump with all the bolts. the key hole is right above it. cant tell you how many times ive put a bolt in there and then have to re pull the cover to pull that bolt!
i stripped the bolt toward the waterpump pulley directly to the left of the key hole. hope i dont need it!!! it was too late to go back in and tap the hole!
(and i had enough of the waterpump job at that point!)
Bill would have dove back in!!!!
MK
Originally Posted by heinrich
Roger ... buy a new set. They are ONLY two lengths. Hold the bloody pump upside-up and hanfg the bolts. All same depth.
Bill: the hole you point out is the dead hole where there is a key stud, no bolt.
Old Mar 5, 2006 | 10:45 AM
mulik51's Avatar
mulik51
Thanks Garth, I was very suspicious of my hand tightening technique....
Klim
