Who's got the coolest wheels? (gimme pix!)
#1261
That's not Mocha. Look here: http://www.landsharkoz.com/htm/sc/colourother.htm
Eric, Those Profil 5's will look great on Turq. Ordered 18" FM5's for the 94 and Fikse 17" Classics on the 79. Great rims. T
#1262
Hi Madturk, Can you tell me about these wheels you posted on the black 928 in the wheel thread? You said they wouldn't work and you may use them on your 911. i have a set of Victor Equipment Innsbruck coming from eBay that look just like that. I think I am going to have a problem with fitting the fronts. Rears are 19x10.5 et55 Fronts are 19x8 et 45.
#1264
I had 305's in the back. Not much of an issue except the front was too low to fit the rears and spacers were used. The fronts unfortunately we're sticking out and rubbing.
I wish they fit right. Absolutely georgeous looking wheels.
Since that I bought 19" Porsche carrera wheels. Me sad
#1265
"Not much of an issue except the front was too low to fit the rears and spacers were used. " Could you clarify this? Can you also reply with what size the wheels where and what offset? What size tires were you using? I have been racking my brain with all these numbers and would love to know all the info from what you tried. How did it drive? I read with a front 45 offset I could get tram lining and stability issues because of scrub radius loss. Thanks- Gunar
#1266
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image_8f8783419f42a79e5edeed6b506a8d20403cb6a7.jpg)
Getting close to finding out if I can make these work.......
#1268
http://www.landsharkoz.com/colourstart.htm
#1272
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image_89f053652c14cff66d1d4dd2623543993338f0c7.jpeg)
All good. The ride is a little more harsh but everything else is great
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image_2c7c2d831db69e685da8ad1c4898aa0ba36447fd.jpeg)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image_8b3bf6e3ed9b8e3dd432eb9204aa697778905a86.jpeg)
PF (04-07-2023)
#1273
Looks great but, 45mm offset is too low on the front.... Do they rub? How does it handle? 52mm offset is about as low as I've been able to fit without issues. 54-56mm would be better option and what is readily available aftermarket or from other Porsche models for our 928s. Could always have a set cu$tom built. Wish you the best.
#1274
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image_79ada7d3849d97b5111044d97297875da57c6786.jpeg)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image_df3b732f0ae86d57825cca0992ed7835bd4146f4.jpeg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image_4a3835257e6f187e514367e98918ac0c8b859b9f.jpeg)
