928 Forum 1978-1995
Sponsored by: 928 Specialists
I fear the worst! Help!
Old 02-13-2006, 09:44 PM
FeedNfrenZ
FeedNfrenZ's Avatar
Default I fear the worst! Help!
New Battery, Alt. 14 volts, replaced starter (used), cleaned battery and engine ground. The engine rolls over slow, starts fine, runs smooth, revs., idles okay. When it gets up to temp. it just flat out dies at an idle. Then barley rolls over. It may start and die. It may start idle rough then settle out. Gun the engine and let the throttle go and it'll die. Try to roll it over again and it'll barely roll again. I put a socket on the crank and I can turn it, not easy but all plugs etc. ARE still connected and in. Let it cool and repeat. It's done this to me several times.
I need help?
One other note: I've just replaced the #24 injectors with #30, adj. fuel reg. and redone the intake during my supercharger install
Old 02-13-2006, 09:52 PM
FeedNfrenZ
FeedNfrenZ's Avatar
One other thing......... no smog pump but cats. still in (hadn't had a chance to install the bypass yet)
Old 02-13-2006, 09:57 PM
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
How do your plugs look? Just hoping you are running REALLY rich...
Old 02-13-2006, 09:58 PM
the flyin' scotsman
the flyin' scotsman's Avatar
When was the last time you loosend the pressure on the thrust bearing?
Old 02-13-2006, 09:59 PM
bd0nalds0n
bd0nalds0n's Avatar
What kind of fuel pressure are you getting?
m21sniper
m21sniper's Avatar
I assume that the motor ran fine before you did the S/C and injector install?
If so, that would almost certainly eliminate the thrust bearing failure that you are alluding to.
That happens over a long period of time, so unless yours was almost shot when you began the S/C install, you should be OK.
Old 02-13-2006, 10:00 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Well, let's get down to it....Have you checked the crank endplay recently?
Old 02-13-2006, 11:16 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
If the engine was fine before the latest mods, I would doubt TBF. I seem to remember Tony going to bigger injectors and having a start problem. So, before we all panic it's time to go back over what changed.
Old 02-13-2006, 11:22 PM
JP Rodkey
JP Rodkey's Avatar
Cam timing.
Old 02-13-2006, 11:42 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
He says - car turns over SLOWLY despite new battery, starter, etc. Dies when warm and BARELY turns over.
Why are you guys suspecting injectors, fuel pressure or cam timing?
Eh, sorry. I guess we should always offer hope!
Old 02-14-2006, 12:34 AM
FeedNfrenZ
FeedNfrenZ's Avatar
Plugs look okay (not wet, no dark carbon, changed them). Air fuel meter shows normal to rich under throttle. Trust bearing has never been loostened to my knowledge. I've adjusted the fuel pressure down to 30lbs. Haven't checked crank shaft play. Did timing belt and water pump replacement while intake was at powder coating shop.
I never had a chance to put many miles on it after Katrina but it definatley didn't do this when I did run/drive it. One other thing that I did notice that maybe unrelated: when in park I rev. the engine and the car surges forward. I've never had that happen before?
Old 02-14-2006, 12:48 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
That's interesting. Does it do this in Neutral too? Torque converter problem. Maybe Steve C will notice and comment.
I think there may be a lubrication problem in the tranny/torque converter. That could be better news that TBF, but it would be useful to check the flexplate for preload at least.
Old 02-14-2006, 10:37 AM
hupp
hupp's Avatar
This may be a shot in the dark, but if possible you may try uncoupling the torque tube from the crank. Start and see if the problem persists. Maybe this will isolate the problem to the tranny.
But then again, running the engine with the coupler slid back on the TT shaft may not be a good idea. My shark is a 5-speed and the short slined shaft could possibly slide out of the pilot bearing and touch off on the TT shaft end. Not sure about an auto set-up, maybe one of the experts can comment.
Old 02-14-2006, 11:20 AM
FeedNfrenZ
FeedNfrenZ's Avatar
I've been inside of a few engines but they have usually been boat engines and never a Porsche. Trying to break the problem down to one common issue, I've come to the conclusion that the engine is simply too hard to turn and when it heats up the metals expand and it can't sustain an idle. I have a hard time believing that it would be a piston/cylinder problem. That to me would be a one time all she wrote issue. SO........... what can cause a problem like this?
More info: Oil preassure has always been good, temp has never run hot, I have noticed that it seems to shift at a slightly higher RPM.
Old 02-14-2006, 11:31 AM
AO
Supercharged
AO's Avatar
Brent-
Unless you feel really lucky, I would get under the car and check the flex plate. Your hard starting and hard cranking are tell-tale signs. You may also want to change the oil and look ofr metal bits. Scott's suggestion about disconecting the TT maybe worthwhile once you're in there.
There really isn't too much involved. Biggest part of the job is dropping the cats (if you have them). After that, 6 bolts on the bellhousing, and you're there. There are a number of write ups I believe. I would do it for peace of mind. If all is good then you can start looking elsewhere - like the tranny, etc.
Quick Reply: I fear the worst! Help!
