Help! Clogged Fuel Filter Symptoms
Talk about buzzard's luck... I took the 86.5 out for a spin this evening as I am getting ready to put it up for auction on ebay and as I was returning home it began to run really rough. I feathered the accelerator a bit to keep the revs steady but it was obvious that something wasn't right. The motor acts like it's not getting enough gas... wouldn't rev above 3,000 rpm... but did get me back home. (Approximately 2 miles from the first sign of distress.)
In the driveway the car would run ... but very rough... wouldn't go over 2,000 rpm without very slow pressure on the accelerator. At 2,000 it would bog down and then quit if I pressed the accelerator quickly, but with very slow pressure I could get it up to 3,000 rpm. There was no smoke, no odor of unburned gas, oil pressure held steady at 5 bar, and the water temp was normal. The car was last tuned in 11/05 and compression in all cylinders was within 5% of spec. I have been running the car on very little fuel as I am trying to sell it. The last potential buyers drove the car for about 10 miles and reported absolutely no problems.
As of now - about 2 hours after I limped back home - the car will start but it's obviously in some sort of distress. Again - it does not want to rev, but there is no smoke or unfamiliar smells from the exhaust.
Unfortunately I have minimal tools, very little time and no garage! If it is a fuel filter problem I can get it to a decent technician (Corvette C5/C6 certified) about three blocks away.
Any thoughts or advice would be greatly appreciated.
Thanx
Thanx
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
It is more likely that you will win the lottery than have a clogged 928 fuel filter... also more likely is your mass airflow has taken a dump...and the car is running on "limp home mode" a stored map in the LH computer for just such an occurrance . Unplug the mass air sensor and see how it runs
Thanks.... I'll have to fire up the WSM CD I just got from Jim Morehouse the other day.
Unless of course someone will tell me where that little jewel is ???
Yes.... I'm one of "those" kind of shark owners. I drive 'em and I clean 'em.. but I rarely work on 'em. This doesn't sound too hard though... sounds like a real low probablitiy of screwin' something up... or my other favorite trick... breakin' something really expensive!
Jerome
Jerome
Under the Lift
The MAF? Remove the air filter box. The center round outlet on the air box base attaches to the MAF. Look down there with a flashlight and you will see the big black electrical plug connected to a black box on the side of the MAF - usually oriented towards the driver side. Wiggle the plug a bit and it will come off.
Thanx!
I probably won't get to it until the weekend - it's raining, and that's supposed to go on for the next several days. (Buzzard's luck....remember... it's been dry and unseasonably warm here in the DC area for the last 3 weeks!)
Well I guess I'll have to make do with the "other car".... for the next couple of days!
Jerome
Jerome
Thanx![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Thanx
Fuel Filter??
Hang in there!
Cheers,
My broken up in tank filter was like that, and the inside of the tank similar, when I pulled the tank - 10 years in Arabia will do that! However, when I cut open the pressure filter, it wasnt badly loaded up with crap, and the car hadnt missed a beat in years.....I doubt that a filter will clog suddenly as described above without somebody helping it along.
jp 83 Euro S AT 50k
jp 83 Euro S AT 50k
Hi Jerome,
If it ends up being your MAF... I have one that I'll trade you for those AA chips.
A new MAF will set you back about $500.
Good luck solving your problem.
D
D
Fleet of Foot
Dave:
That is one UGLY, fossilized filter! Never seen one THAT ugly before.
Yes that was the "before" after I dropped the tank this summer. Found all kinds of stuff in the tank .. everything except gasoline, I might add.
This is what it looked like after I cleaned it, right before reinstallation.
Cheers,
