Vacuum Pumps on 32V Cars
Hi Sharksters,
I am curious to know if any of you are running a Vacuum Pump on your modified 32V cars. I am thinking of installing one, and wanted to get comments from anyone who has already done so..
What type of VP?
How much Vac is it pulling at max Rpm?
Any before/after dyno runs to compare?
Real plus if you have done this mod and your car has an iron lung or the like..
I have attached a pic of a VP that I think can fit where the current airpump lives..
Smog won't be an issue for me, my techs are very friendly to me...!
Thanks,
What type of VP?
Thanks,
That one looks nice and compact. I will be installing one with my V-1.
Brendan,
It's about 5" X 5" in size, very similar to the airpump..
Anyone else at least thinking about this....? Especially all the boost freaks with those catch cans that have to be drained all the time...
Hmmmmmmmmmmmm...............................................?
Professor Louis....?
Is this the one that Porken mentioned? Is this one okay with the oil mist? I would assume it has to be separated before the pump?
Originally Posted by blau928
Brendan,
This pump needs oil to lubricate the wipers... The separator is placed after this pump...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Inventor
(Here's) the last thread where I asked the same question.
Here's some good articles on the GZ pump:
DRO Tech Section - Power from Thin Air - 1-7-05
DRO Tech Section - Power from Thin Air Part 2 - 2-9-05
To keep the pumps happy on the street, they use a separator which always drains some oil back into the pump feed line.
The thing is that I hooked the air pump up directly to the top of the seperator on the early canister style cars. No other way for air to get IN the engine. There was a plate I installed at the base of that canisteroil fill separator thing and it was drilled on the non-direct side to let air through but not as much oil.
The thing pumped about 2 quarts up and into the air pump in about 5 minutes. Puddles of it were comming out the exhaust of the ait pump.
That second article mentions to have NO WAY for air to seep INTO the crank case. How are they not simply pumping oil up into the heads and into the pump?
Is the 928 engine THAT BAD at crank case oil control? Or so I just continuously get this**** wrong?
Inventor
Perhaps the lower drain hose to the crankcase was the problem? With the restrictor plate, the pump may have been pulling and/or oil may have been pushed by blowby up the drain pipe*.
I'm going to block off the pipe with the factory plate when I ditch the separator tower.
*The bottom of which is under the top of the oil level.
I was only pulling from the top of the oil filler cap.
My theory:
Attach the VP before the A/O separator.. The oil drain then goes from the separator to the sump, or possibly the Valve Covers... Air gets vented into ATM, past the cats into the exhaust, or into the Intake of the SC (pre Filter) as it should be relatively clean.
I also plan on using a Vacuum valve/limiter so as not to suck up too much oil into the pump.
The point of evac from the engine will be at the oil filler area on the block just behind the Water bridge..
On another note, the SC will be fed pressurized oil from the engine oil line, and drain to the sump or the Valve Covers...
Comments...?
Comments...?
Brendan,
I checked with Moroso and probably other vacuum pump manufacturers and found none who recommended their pumps for street use. Apparently in drag engine use they don't last very long and need rebuilt every 10 runs or so. These GZ pumps are the only ones I've seen that are recommended for street use. Who will be first to dig deep and try one of these?
